![Very Happy :D](./images/smilies/icon_biggrin.gif)
Do coilovers fit
Do coilovers fit
Suby tech on the way
Coilvers for a GC8 Impreza will fit, this I know for certain. I asked someone to check and see if the EDFC would fit on the BF Legacy and was told that it wouldn't, because of hood clearance issues.
Legacy Central
Coilovers generally have higher tolerances in valving (not to mention being adjustable, they have moving parts not found on regular struts), and as such they require maintainence. Seals mostly.
Generally, expect 20,000 miles or so for rebuilds if you track the shit out of them. Actual life is ENTIRELY depentant on driver and terrain.
I've found DMS struts to be of horrible quality, and I'd stay away from them like the plague.
Tein's are nice, HKS and JIC tend to be slightly more track biased and harsh. H&R, I've heard and seen nothing but good things, and GPMoto's LOOK good though I have yet to actually drive a set of them.
The only WRX coilovers you should use would be the ones that have height adjustability independent of spring preload... (ie JIC FLTA2)... since WRX rear suspension uses longer struts than the BC/GC chassis.
Trying to match overall strut lengths by using only preload adjustment will really mess up the ride quality
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
1990 Rover Mini 1000
2004 Forester XT
he doesnt like the DMS 40/gold. he had a bad exerience.skid542 wrote:Sorry for the half hijack, Phil, you don't like DMS?
the DMS 50 and 60 for gravel rally are much better units.
hotbits is another brand you should check out. pretty competitively priced.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
I'm another one that doesn't like the 40/Gold models...bad experience with them.
So far my two experiences with Tein have been fair to exceptional. No JIC experience, but they seem to be popular and are gaining ground on this side of the Pacific.
Legacy Central
life expactancy of a coilover is not dependent on driver so much as it's dependant on the parts used for building. Customers of mine have 50k+ miles on their coilovers. installed on the car since new, with no issues.
coilovers from the GC chassis will fit, did it on my legacy before it was sold.
Teins, really and honestly are crap. If you enjoy the ride they give you, then you're really going to enjoy a set of quality made coilovers. shitbox engineering. I caught these fools taking notes and photographs in my booth at SEMA. They left without arguement.
DMS has poor tolerances and quality control. They are nice to begin with, but need rebuilding often.
GPMoto doesn't build their own units, they're pieced together using other peoples parts. What's that mean? They aren't actually engineering, they're just parting.
JIC = too harsh for daily driving, shitbox engineering. Also caught these guys taking notes and photographs in my booth. They didn't want to leave so easily. course, they didn't speak english, so they arguement was short.
edit to add... stay away from coilovers that have a wide range of dampening "adjustment." its another way for the manufacturer to cheat and not have to engineer the damper for your car. Those coilovers just use an insert that is used on a wide variety of apps. You'll spend 3/4 of the time you own them trying to "tune" your suspension. This will do you more harm then good.
another addition: If you're street driving, you will soon grow tired of any spherical bearing top mount. These transfer A LOT of NVH into the car.
-Jason Grahn
Not "officially" as "officially" my company doesn't manufacture a coilover for the car but.....
when i swapped to coilovers, i used H&R part number 29375-1 for the GC impreza. The handling was superb, the ride quality was awesome. I could drive that car anywhere. My girlfriend at the time really enjoyed the ride quality of the car too. They're pricy, but they're awesome.
-Jason Grahn
Loose and semi packed gravel and rough conditions as pot holes, 'corregated' surfaces, airborne (this would obviously be coupled with chassis stiffening upgrades and control arm/links upgrade).
I was under the impression that's where the larger DMS excelled at but that impression appears to be wrong so I'm curious as to what is the best in those situations.
Lee
The DMS DOES work really well for this, but know that you ---WILL--- have to rebuild them often.
Now that we know this is a competition vehicle, not a street driven car, we can take better action toward finding the correct setup.
Ohlins - VERY good.
Proflex - VERY good.
Reiger - VERY good.
Ohlins - VERY good.
Reiger - VERY good.
-Jason Grahn
This amuses me. So many people talk about Tein like they are god.
I know you said the DMS dampners are pretty loosely put together, but how do you feel about their double-progressive wound springs? Seems like a really good concept.
Untill I feel like spending the loot on full coilovers, I was thinking STi pinks w/ KYB AGX's. Matching top mounts of cource. I'm only looking to lower the little bit that they do and I've heard nothing but good things about the pinks. (not JDM) Opinions?
I'll go with Jason on the Teins not being the greatest, especially on North American roads. On my BF, using GC8 coilovers and Pillow-ball mounts, it was...stiff and noisy.
The BE, with NA coilovers and some softer kg/mm springs is actually pretty close to what I'd expect from a normal strut/spring setup, which I'm all for.
Legacy Central
blah blah blah, double progressive = buzz words. Progressive vs. linear is a question not worth asking anymore when it comes to proper suspension design for a street driven application.
For racing, sure, maybe. at the top levels of the sport, definitely. lower levels? no way. you have other things to care about.
DMS isn't doing anything new. DMS have a tapered spring - old technology combined with a very slight progressive wind - old technology. There are better ways of doing things. all that tapered spring does is add to the cost of the package.
-Jason Grahn
Oops!
I've got Whiteline bars on the twgn and have been planning to install DMS
springs. These can be ordered with the standard ride height and spring rates.
Wgn spring rates and stiffer bars provides a reasonable ride with good control of transitions from turn to turn. Also intended to install the Tein
adjustable shocks(edfc)
If the latter wont fit under the hood, then I'll have to use manually adjustable ones.
Any suggestions on the latter?
![Confused :???:](./images/smilies/icon_confused.gif)
