Import legacy fuse box picture - 16(EGI/TCU) under the dash?
gramps_rs
Post by gramps_rs »
Have tried shifter sequence to reset the ecu but was going to try pulling fuse 16 out.... Which one is it, picture of my foot well fuse box cover. cheers
These should be "similar"
http://www.main.experiencetherave.com:8 ... ns/118.jpg
http://www.main.experiencetherave.com:8 ... ns/119.jpg
You can verify them by checking the amp rating.
gramps_rs
Post by gramps_rs »
Thanks mate, you love your manual scans hey! There good stuff though.
When you say reset ecu = pull fuse 16 are you talking about the fuse box under the hood? I was under the impression it was the inside box, under foot well....
It should be fuse 14....not fuse 16.
It's the far right one on the second row in your pic. It's 10 amp, and says EGI AT on it.
gramps_rs
Post by gramps_rs »
youre a legend, cheers
