Hi, I am buying a 91' legacy and I have a choice of getting some 17" OZ's or some stock 2.5RS wheels.
The problem is the 17's rub. I don't know what series the tires are so I cannot tell if I can go down a series and be fine. Is there any other way to make it permanently not rub? I know rolling the fenders can help. Is there any other way? Thanks.
17" O.Z's rub
17" O.Z's rub
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
dscoobydoo
what size tires are on the 17's? I am running 205/55/16s with an inch drop and there is not a bit of rub. This means you should be able to run 215/45/17's and there should be no rub there either.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
dscoobydoo
Ok, I have 17" O.Z. Rally rims. with 225/45/17 tires. I found some cheap nitto's on discount tire direct's website that were 215's.
I am thinking of running 215/40's. just to be safe, I don't think the sidewalls will be too stiff.
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
BAC5.2
I run 225/45/17's and they barely rub. It's all about fender rolling. I only rubbed in the rear, but I rolled all 4.
215/40's would be OK, but that's a TINY sidewall. You run the risk of denting the hell out of the rim.
A 215/45 should be fine though.
dscoobydoo
205/55/16 is pretty much the same mathematically as 215/45/17 height wise. 1 cm wider approx. I think you should be able to fit the 215's but 225's is probably the reason for the rub.Imprezive wrote:Ok, I have 17" O.Z. Rally rims. with 225/45/17 tires. I found some cheap nitto's on discount tire direct's website that were 215's.
05 GD-STI
00- GF
05 GD-STI
00- GF
