it gets to "reading rom ID" and thats it....
i grounded it on the main ECU ground wire where the 2 go to 1 wire, would that be a problem..? seems like the most logical place.
does the ECU need to have full power to it? ignition power? my battery is almost dead, but hooking it up to a car by jumper wires and it still didnt work
i need it to work so i can tell what ELSE is wrong with my wiring job!
(ECU is in my impreza)
any ideas of what i should check or why it wouldnt work? im taking the select monitor wires straight from the ECU where i cut them.
thanks for any help!
