How much performance can the OEM Bypass Valve handle?
Subtle
Post by Subtle »
This winter I intend to drop a TD05-16 turbo into my twgn.
It has a fmic, stainless exhaust(3-inch), stand alone SDS ecu, and a built 4eat. :)
Should I upgrade the bypass valve :?
dzx
Post by dzx »
TDO5H-16G? If you have a front mount, you might as well go to a bov. Greddy's bov can be recirculated.
///M
'93 Legacy SS - part out
Subtle
Post by Subtle »
The current install is tidy and I prefer the recycle over the vent to the atmosphere type of valve.
Subtle
Post by Subtle »
What makes up the class 4 mods?
Post by 555BCTurbo »
I was running 19psi with a stock BPV, and it worked fine...
I found it easier to fit a cheaply available Bosch BPV with my 16G than to try to make the OEM valve fit.
wiscon_mark
Post by wiscon_mark »
A member on SL-i modified a WRX Bypass Valve so it could take 24psi, I believe.
His username is Xcntrk75
185,000 miles
BAC5.2
Post by BAC5.2 »
He just crushed it. Lots of people do that.
My stock valve was incapable of handling the air.
I've had various atmospheric BOV's and I can't wait to go back to recirculating.
Most good valves can be recirculated.
wiscon_mark
I thought he beefed up the spring...
185,000 miles
georryan
Post by georryan »
555BCTurbo wrote:I was running 19psi with a stock BPV, and it worked fine...
Are you running any other engine management (ecu/piggyback/injectors)?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
Subtle
Post by Subtle »
Geo
Stand alone SDS ecu, with down loadable wide-band, or whatever it' called.
Profec B controlling the waste gate. Set at 7.5 and 12.
azn2nr
Post by azn2nr »
my stock bpv on a fmic and 16g couldnt vent the air qick enough. lots of surge. holding was not a problem
-jason
Subtle
Post by Subtle »
BAC5.2
What ecu are you using :?
Thanks------- Bob
White Out
Post by White Out »
I am not sure if they use the same recirc valve, but my crushed oem held on the STi to 24psi.
1987 Buick Grand National
2003 WRX Sportwagon - ej207/vf30
2004 STi - built motor/gt35r
93Leg-c
Post by 93Leg-c »
What does the term "crushed" mean?
'94 TW
dzx
Post by dzx »
Subtle wrote:What makes up the class 4 mods?
Aftermarket turbo kit
Engine management
FMIC
Cams
Fuel system
flywheel and stuff
I dunno, but i figure it would qualify for a stage 4 if there was one. :smile:
///M
I hate the whole stage terminology....it's such bullshit. It means absolutely nothing. I have stage X from this company....well I have a stage X from another company.....Are all these companies going to get together and say, ok stage 1 has these parts, stage 2 has these parts, etc. Same goes for power increases.....
Anyway...my little rant.
dzx
Post by dzx »
stage x, i like it. lol
///M
bmxpunk
Post by bmxpunk »
hahaha
dzx you have a stage 10 leggy!?!?!?!?!?
HAHAHAHA just kidding. roman numerals rule!!
agreed on not liking the stages though.
2011 Mini Countryman S All4
1970 Honda Ct90
2001 Forester S of Doom - mowed down by a Cummins
1994/5/6/01/02/03/04/06/07/08 Impregacy OUtback SS STi Type R money pit- NEW RALLYCAR!!
I was meaning X as in a variable ;)
bmxpunk
Post by bmxpunk »
I know. i guess i put the just kidding in the wrong spot.
as far a bpv input----my fried is using the leggy one on his rs-t works great 7psi ;)
1970 Honda Ct90
Subtle
Post by Subtle »
OK--the suspense is killing me.
What's a "crushed" bpv :?
bmxpunk
Post by bmxpunk »
you crush the top of it inorder to add preload to the spring, making it feel stiffer
1970 Honda Ct90
BAC5.2
Post by BAC5.2 »
Yep. Can't do it with a stock BPV though.
I wasn't running any engine management to speak of really.
I'll be doing things the right way soon enough though.
supermoose
Post by supermoose »
crush bov?
trick from the DSM guys. put bov in vise, ups the spring rate. duno personally, never done it.
