AWIC Pump wiring
georryan
AWIC Pump wiring
Post by georryan »
I want to wire my intercooler pump into the ignition. Basically I'm thinking of only having it run when the ignition is turned on, and it will still be off on the accessories position. Where is the best place to do that?
I was thinking of putting a switch into the line as well in case I want to disable the pump for any particular reason.
Where did you wire your pump Josh?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
I haven't wired mine up, but I'll probably do the ignition as well. I may tie into an ignitoin lead in the electrical stuff behind the battery (still not sure yet) or just run a line from in the cabin.
