Garbage Spongy Brakes.
You shouldn't need to bench bleed it.
I've swapped out MC's twice. The first time I tried to "bench" bleed it. I successfully ended up just creating a massive mess....that's all.
The second time, I put the MC in dry, did a thorough brake bleed, and never looked back.
I have done TONS of brake jobs on all sorts of different cars, and NEVER bench bled anything, and my brakes have always been good...
I really don't see the point in bench bleeding, because I figure you can get that air out in the system with a good bleed...
I am thinking about investing in a MityVac to bleed brakes in the future...it seems like such a better/easier method
Art - Doing the RacingBrake 4-pots? We did a set of those with 2-peice rotors on an LGT Wagon. That thing was sick.
It also made 330whp and looked almost entirely stock. It was fucking GANGSTA!
Your MC is actually smaller in diameter then the one on laurels. The LGT has a 1" bore MC, while the turbo legacy has 1-1/16". The LGT has a significantly stiffer booster, which helps with pedal feel, and such. The caliper are also probably stiffer, which is why they can probably use the smaller bore MC.Yukonart wrote:Hmmm. . . Laurel will be getting my brakes in another few months anyway. . . I wonder if we should just include my MC with the swap and call it good?
Personally, I'd just do the brakes and see how things feel/stop. If she's happy, leave it at that.
STi Brembos . . . they'll go on when I source an STi 6-speed sometime in the spring. Also looking into upgrading the hubs to 05-06 STi spec. . . so the wheel bearings will be beefier, and I can shop for wheels that will fit over the brakes from either 05+ STi or 03+ Evo specifications.BAC5.2 wrote:Art - Doing the RacingBrake 4-pots? We did a set of those with 2-peice rotors on an LGT Wagon. That thing was sick.
I plan to do similar things to the wagon . . but transmission and brakes come first. . . followed shortly thereafter by suspension mods.
1994 & 2005 Legacy GT Wagons
Sounds like a good idea, Josh. If we need to at a later time, we could swap mine out for hers, too . . . when I get the braking system from an STi onto my car, I'm sure I'll be able to snag the MC as well . . so it'll be around, anyway.Legacy777 wrote:Your MC is actually smaller in diameter then the one on laurels. The LGT has a 1" bore MC, while the turbo legacy has 1-1/16". The LGT has a significantly stiffer booster, which helps with pedal feel, and such. The caliper are also probably stiffer, which is why they can probably use the smaller bore MC.Yukonart wrote:Hmmm. . . Laurel will be getting my brakes in another few months anyway. . . I wonder if we should just include my MC with the swap and call it good?
It helps a little. I've got the brace, but the strut tower that the brace is mounted to still flexes.93forestpearl wrote:Nobody has mentioned bracing the MC. I thought that was an issue with subarus.
I know I'm digging up an old thread, but I didn't think this needed a whole new thread....
Anyone here have any tips for rebuilding the master cylinder? I am considering doing this, and am too cheap (not to mention broke) to buy a new one.
Is there a MC rebuild kit for our cars? If so, what's the part #? If not, what all is needed? I have an o-ring service kit with just about every size o-ring I could ever need in it.
Rio Red '91 Legacy SS
I kind of doubt they make master cylinder rebuild kits. For liability reasons, I can see someone suing the company for a rebuild the end user did wrong. It's probably just as cheap to get a new one & a lot faster.
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
'05 Corolla XRS
True.
I found a rebuild kit online for $99 and a rebuilt MC for ~$60. I may disassemble mine and look it over and figure out what I should do from there.
First things first, though, I am going to rebuild the front calipers, get the rotors turned, and install SS lines and new fluid.
I had the spongy-feel and "pump to get solid feel" on my car as well. Suspecting an air bubble, I bled twice, and changed the master cylinder to no effect.LaureltheQueen wrote:It still won't fix the spongy feeling that i get. It brakes better if I pump the pedal.
My fix: Turned out to be frozen slide pins on the front rotors. They were just totally stuck. I knocked them loose, cleaned thoroughly, greased and used new slide pin boots, and the pedal went back to a much more solid feel. The back needed the same treatment and improved again when I smooth-ified them too.
Much more solid feel = still a touch soft, but acceptable soft not "nearly to the floor, OMG!"
It's a cheap fix; only costs are grease and the slide pin boots for about $8 total and my time.
