The best pictures will go below here. I'll describe as many as I can below each picture. Everything else will be in my Photobucket.
DSF = Driver's side front
PSF = Passanger's side front
DSR = Driver's side rear
PSR = Passanger's side rear
Intake
No pics yet
Engine Bay
NGK Ignition wires
NGK Ignition wires
Exhaust
This setup lasted for about 8 minutes, then the cords melted. Its held on with strapping now.
Suspension
Sway bar bushings (DSR)
Sway bar bushings, endlink unhooked (DSR)
Bottom endlink bushing (DSR)
Cracked endlink bushings (rear)
Wheels, Tires & Brakes
No pics yet
Exterior
Interior
Junk in the Trunk
SS Seats
Driver's side dash
Dash
Behind the instrument cluster
Car PC
New CarPC/Sub setup, took out the carpeting.
Pulp Fiction (camera flash washed out the screen pretty bad)
The wiring is pretty horrible
This is what makes the music work
From the back seat
