FS: Turbo and N/A Parts (PA)
Re: FS: Turbo and N/A Parts (PA)
hey all
this place is awsome, there is everything you need for your vehicle, good price and good quality, frank is a awsome guy, i greatly reccomend it. I was there this weekend and i will go back for more, it feels like you are in a candy store when you were a kid.
thanks again
Neo
thanks again
Neo
1990 L 2wd 5spd 215K miles
Do you have a turbo legacy overflow tank?
You mean the tank up near the intake manifold or the white plastic bottle next to the radiator?
I need the turbo specific white plastic overflow bottle.
Thanks again!!
I got the Diamond coil pack, installed it, and it works!
My mechanic friend was checking out my new fixer-upper '93 ss, and he asked me, "Do you hear that?" I said, "Hear what?" "I think your coil is leaking." "What do you mean?" "I can hear sparks grounding coming from it." I wasn't sure if he was joking or not but he assured me he wasn't and recommended I get a new coil and wires. I told him, "I know where I can get a coil for $25 used." "Get it," he said.
Now, I always thought I had good hearing but I couldn't hear what he was hearing. So, since I didn't have a meter, I did the night test on it--in the darkness of night, I had my engine running and opened up my hood. Wow, what a light show in there--blue sparks grounding out in 5 places (2 from coil and 3 from the plug wires). So, I bought a Diamond coil pack from Frank (blackbart), installed it, and pure darkness--no sparks grounding from the coil!
Thanks Frank! Got your package in two days!
'94 TW
How about the power window switch assembly from the drivers-side door?
Door lock motors?
Window lift motors?
Wastegate control solenoid?
Charcoal canister?
I may be interested in the ECU as well, if you can get me both sides of its connectors (cut the wiring harness instead of unplugging it)
Let me know.
Door lock motors?
Window lift motors?
Charcoal canister?
Let me know.
-Chris
91SS 4EAT stock
91SS 5MT awaiting engine rebuild and VF36...
92SS 4EAT - RIP![Sad :(](./images/smilies/icon_sad.gif)
94SS 5MT4.11+rLSD 289k km: RobTune550,TD05-16g @ 18psi,FMIC,3"TBE,Forester lift
91SS 4EAT stock
92SS 4EAT - RIP
I can pull all that stuff on the list, do you need a Turbo ECU or N/A?free5ty1e wrote:How about the power window switch assembly from the drivers-side door?
Door lock motors?
Window lift motors?
Charcoal canister?
Let me know.
I have a turbo ECU with the harness conector and a few inches of the harness wire. I think I also have an N/A 5MT ECU with some wires.
Yes, NA and turbo AC hoses are different. The turbo hoses have a metal pipe somewhat like an inverted "V" to keep it further away from the turbo whereas the NA hoses have more hose and run horizontally across the engine bay to the connection into the firewall.Blackbart wrote:Are the N/A hoses different than the turbo? I have 90 N/A, 91 turbo and 92 turbo.93Leg-c wrote:Frank, do you have a NA AC hose in good condition--the long one that connects up at the firewall? If you do, what's your price on it, please?
However, I know that some engine parts of the NA '90-'91's are different than the NA '92-'94s so I'm not sure if they are interchangeable nor do I know if the '90 NA hose will fit on my '93 turbo.
I'm planning on installing an IC so I'm lookin for a NA AC hose. The inverted metal pipe on the turbo AC hose will get in the way of the IC.
I'll see if I can find out if your hose will fit my application.
Meanwhile, anybody on the Board knows if the '90 NA hose will fit my "93 ss?
'94 TW
Cool - the turbo ECU with the harness connector and few inches of harness wire would be good.I can pull all that stuff on the list, do you need a Turbo ECU or N/A?
Hey, you mentioned a 91 SS? How much for the rear differential?
-Chris
91SS 4EAT stock
91SS 4EAT stock
92SS 4EAT - RIP
Help
My 1994 Legacy L 5 speed N/A tranny just bit the dust do you have a good tranny available and can it be shipped?
Thanks Dean...You can email me at "v8killer2pt5@aol.com"
Damm this does not feel like my Sti!
This is going to seem pretty random...but...
I need some fabric like that which covers the door panels and center of my seats on my 93SS. It's a grey color with blue and red (and maybe green? can't remember) stitching. I just need a 4" by 7" piece...if you have a car with trashed seats or door panels that you could salvage it from, I'd GREATLY appreciate it.![Smile :-)](./images/smilies/001.gif)
The only interior I have with that pattern is my daily driver, I will keep my eyes open for you thoughHigh PSI wrote:This is going to seem pretty random...but...
![Shocked :shock:](./images/smilies/icon_eek.gif)
Frank thanks alot, I just sent you payment. Hopefully I can get the parts by Friday, I appreciate the help and effort. With any luck things will go ok and this will take care of the issues I am having. ![Smile :)](./images/smilies/icon_smile.gif)
Hey do you have mud flaps and fog lights if so PLEASE LET ME KNOW.
Thanks Spencer
Thanks Spencer
