4eat trans won't shift
My 4eat trans won't shift when it's cold out. It does fine from 1 to 3 but won't go into 4th when it's cold out in manual or automatic mode. Once the car warms up it does fine. Has anyone else here had a problem like this? Any idea what may be causing it. I'm guessing it has something to do with the tranny fluid thickening in the cold beyond that I don't know. Trans pump??
--Scott--
1991 - Rio Red SS
1991 - Rio Red SS
I noticed the same thing in my touring wagon, won't go into 4th until it has warmed up. this is when the temps outside are cold, which is everyday in iowa now. It kinda suks, cause I live right off the interstate, and when i pull out on the highway and it stays in thrid even though I need to cruise along at 70mph.
Anyways, I blew out the Driveplate, so it is getting repaired soon. Also going to fix the broken speedo drive gears inside the right side axle, as I want to get my speedo back and have a working cruise control.
anybody else know if not shifting into high gear until the tranny warms up when it is very cold out is normal.
b
b
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
4EAT will not get into 4th until the ambient temp inside the tranny is 40 - 50F.
TC locks up at 150F.
It's NORMAL!!
