Moderators: Helpinators , Moderators
shemoves
Posts: 289 Joined: Tue Aug 02, 2005 6:53 pm
Post
by shemoves » Tue Jan 17, 2006 8:30 pm
I would like to get some new wheels for the legacy ('94 SS). I am assuming that the bolt pattern is 5x100, but I am unsure what the offset is. I just bought new tires, so I'd like to keep the same size. Any suggestions?
Posts: 12517 Joined: Sun Nov 03, 2002 2:13 am
Post
by vrg3 » Tue Jan 17, 2006 8:46 pm
+55mm.
Posts: 27926 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Tue Jan 17, 2006 9:17 pm
If you go with a larger diameter/wider wheel you'll probably have to go with slightly less offset to get things to fit.
shemoves
Post
by shemoves » Wed Jan 18, 2006 5:44 pm
offset is +55...thanks. I don't mind same size. What is the diameter/width of the turbo alloys?
Post
by vrg3 » Wed Jan 18, 2006 7:32 pm
15" diameter, 6" width.
I would suggest you consider upsizing a little; if you do, you can make room for WRX front brakes, which are a cheap and effective brake upgrade.
shemoves
Post
by shemoves » Fri Jan 20, 2006 6:56 am
I just bought new tires (Pirelli P3000) that have somthing like an 80k (720 tread
) mile rating...that's wht I am wanting same size.
QuickDrive
Lurker-King
Posts: 1050 Joined: Mon Nov 03, 2003 8:36 pm
Post
by QuickDrive » Fri Jan 20, 2006 9:55 pm
Sell the tires and upgrade to WRX Wheels and tires for cheap.
Exact fit and a nice look upgrade.
Nasioc usually can deliver a set local to you and cheap quite easily.
R I P-------- 91 Turbo 4EAT --------R I P
