Installing a JEC MAF in place of the Aluminium MAF - results
douglas vincent
Post by douglas vincent »
Positive results.
I would max out the aluminium MAF at 5500 rpm or so, pegging 5.1 often.
Installed the JEC. 4.6 at 6500.
You do run rich though, so you need something to pull fuel with. I did some "live" tuning sitting in my driveway with the Perfect Power. I already had a -8 for idle and so the car started right up. I put in 0 and it started to bog and cough. I stuck in a 3 and it killed. So I am running a -8, -7, -6, -5, -4 ,-3, -2, -1 up the 0% deflection.
I will need to do some more dyno pulls to watch the wideband O2 to see if everything is close, but I suspect I am pretty happy now.
skid542
Post by skid542 »
That's awesome.
Lee
dzx
Post by dzx »
So it was running rich enough to kill your car? Are you still maxing out the maf? I was thinking of doing this since there are quite a few jec's sensors at the junkyard here. I thought you had a n/a maf to begin with?
///M
'93 Legacy SS - part out
dzx wrote:So it was running rich enough to kill your car? Are you still maxing out the maf? I was thinking of doing this since there are quite a few jec's sensors at the junkyard here. I thought you had a n/a maf to begin with?
The 90-91 MT n/a's came with the Hitachi ECU's & aluminum MAF's.
douglas vincent
Rich enough to be boggy.
I am unable to test the maf to maf as a complete stock set up currently, guess why.....
But, when I had swapped the MAFs awhile ago on a different vehicle, the vehicle wouldnt run.
The ECU's throwing a code 49 now, right? That might be causing some of the richness. The JECS sensor would actually show a lower voltage at a given airflow than the Hitachi one, so you'd actually expect it to lean things out some.
If you're feeling daring you could try grounding the blue wire at the MAF sensor's connector to trick the ECU into thinking it's still the correct sensor, eliminating the code 49 and any associated failsafe behavior.
douglas vincent
You know, I just always made the assumption that it didnt run because it was too rich.
But....At -8 fuel while at idle, it idles just fine. At 0, it bogs and chokes at idle. at +3 at idle, it kills. So it does appear to be running rich.....Just no Wideband prooof. Anyone want to buy me a wideband?
azn2nr
Post by azn2nr »
rich will kill the car. in the snow if i load the motor up and let off so the bov goes off. it has enough richness along with the wheels comming to a halt that it up and dies.
-jason
dzx
Post by dzx »
I wonder how the turbo ecu would respond to the plastic jecs maf
///M
sammydafish
Post by sammydafish »
which Jecs MAF did you use? Is this one from a Nissan? I remembe some talk about trying one from a Z32
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
douglas vincent
The NA 91-94 version
douglas vincent
If you have the Perfect Power program installed, you can load this 2nd, 3rd and 4rth gear pull and see that I max out at 4.59
http://www.vincentfurniture.com/photos/ ... MT6030.raw
sammydafish
what did you do about the wrong AFM code? did you get it and did you do what VRG said?
- Junior
douglas vincent
Nothing yet. I did cut the wire but it didnt do anything. I just left the CEL on. It comes on all the time anyway due to misc stuff.
Ground the wire.
Project_Legacy
Post by Project_Legacy »
so, basically wat you are trying to get at is that the legacy N/A MAF from 91-94 would be better for... boosted N/A's? uhh what else would this help with? SS's and TW's with upgraded turbos? i cant quite figure it out... :?
00 5MT AWD 2.5 RS - New Project
douglas vincent
ANY boosted legacy.
The aluminium MAF which came on early NAs and all Turbos max out the voltage versus airflow at a lower airflow compared to the plastic JECs MAF.
douglas vincent
Hey, grounding the blue wire worked!
I missed the "blue" word and had done the white wire, which doesnt have a tab on the aluminium maf, instead.
Started the wagon, NO CEL!
douglas vincent wrote:Hey, grounding the blue wire worked!
Do you notice any difference in how the car runs now?
douglas vincent
Not sure yet. While I did drive 250 miles today since I did the blue wire ground, it was almost all 3rd, 4th and 5th gear miles on freeways and highways. The hesitation was "maybe"(?) less, but I did get awesome (comparatively) milage. The milage went up to over 20 from an average of 14.
dzx
Post by dzx »
when you cut the blue wire, did you ground the side coming from the ecu?
///M
douglas vincent
You T- the wire, not cut, and ground.
Arctic Assassian
Post by Arctic Assassian »
I need to get me one of these.
Kickin' it old-school.
dzx
Post by dzx »
Thanks Doug, that would have driven me mad for a while.
///M
Boostedballs
Post by Boostedballs »
Ok, so I will see a performance increase by switching my aluminum MAF for the plastic one from a N/A car?
What's the deal with the Nissan MAF?
I'm still having issues with surging under boost and the MAF and MAP are my next shotgun parts.
Air-to-Water Intercooler, VF-39, 550 injectors, AEM FIC, stainless race header, 3" stainless exhaust, 75hp Nitrous, 150psi H2O injection, intake mods, stock: long block, 4EAT, ecm.
