I did a search and found nothin in specific to 1998 legacy wagon running 04 USDM Sti springs and struts.
Can awayone give me some advice b 4 I do all this work.
Will the rear sag with 04 STi struts and springs?
Drifting STi
It would help if you could find the spring rates for the STI. Chances are they're pretty high, so you won't have to worry much. Someone should compare the gross weight of a 98 Legacy wagon and an 04 STI...
Legacy Central
JasonGrahn
Drifting STi
JasonGrahn
Drifting STi
JasonGrahn
