weird happenings
The Scooby
ya i know what ya mean...
well changed out the fuel filter, thinking maybe its not getting proper fuel pressure at WOT, well didn't change anything.
so im lost, i cant afford a shop to check it out, and cant afford a laptop to check it out my self.
this sucks.
this sucks.
1986 GL wagon
EJ'ed and Lifted
1986 GL wagon
EJ'ed and Lifted
The Scooby
FINALLY!!!!!!!!!!!!!!!!!!!!!
FIXED IT!!!
TPS sensor, it was giving a bad signal to the ECM, i ajusted it and now it runs perfect at WOT, but low end its having that problem, so i am going to switch it out and hope for the best.
thanks everyone for the help!!
FIXED IT!!!
1986 GL wagon
EJ'ed and Lifted
1986 GL wagon
EJ'ed and Lifted
The Scooby
The Scooby
The Scooby
could this problem be a boost leak? if i remember correctally it all started after i test fitted my TMIC on. could be that i forgot something and its leaking out the boost, my gauge is hooked off the intake and my TurboXS MBC is hooked to the compressor housing and the wastegate.
1986 GL wagon
EJ'ed and Lifted
1986 GL wagon
EJ'ed and Lifted
