Engines with two superchargers
Subtle
Post by Subtle »
In 1951 Formula 1 rules were 4.4L unsupercharged and 1.5L supercharged.
On the latter, Alfa Romeo was formidable with its in-line 8-cylinder,DOHC engine. In 1938 ,with a single Roots blower it developed190HP at 6500 rpm.
At its maximum developement in 1951 the output was 404 HP at 10,500 rpm, from two-stage superchargers. Races typically lasted for about 4 hours. Without intercooling, huge amounts of alcohol and other exotic additives were used to chill the charge and to stave off detonation.
That's 404 hp out of 1.5 L in 1951!
Fuel consumption was 1.5 mpg, which became hopeless as Ferrari's 4.5 N/A developed enough HP in 1952. Alfa retired when they were ahead.
douglas vincent
Post by douglas vincent »
Boat motor
douglas vincent
Its a Viper
douglas vincent
1000 hp twin supercharger BMW 3.6 liter M5 engine.
douglas vincent
All of these appear to have a single supercharger feeding separate banks of cylinders.
That Mercruiser feeds a common plenum.
I can't tell for sure, but those are centrifugal compressors oon the Mercruiser, aren't they?
douglas vincent
Actually, all of them are.
dzx
Post by dzx »
I saw a twin supercharger on car and driver tv a few years ago. It was on an old GTO
///M
'93 Legacy SS - part out
206er
Post by 206er »
Ive seen some hot rod with a big block that had twin 6-71's on it.
Subtle
Post by Subtle »
By two-stage supercharging they meant the first one pressurized the second one.
This was also the case with the Rolls Royce Merlin of World Two that powered the Spitfire, P51 Mustang fighters and the Lancaster 4-engined bombers.
This was a dohc V 12 engine with a 4-valve head and two plugs per cylinder. Displacing 27L it was rated at 970hp at 12# boost at 2600rpm @ 12500 feet. That was in 1938. By the end of the war it was stretched out to 31L, called the Griffon and was putting out some 1800hp.
The sound of this engine is incredible--Straight out exhaust stacks that in poor light could be seen belching flames.
It makes going to an air show worthwhile :-D
sammydafish
Post by sammydafish »
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
snowboarded
Post by snowboarded »
I like the banks.
[quote="Manarius "]Only flamers will get those. [/quote]
[quote="All_talk "]How many WHP will that give me? :)[/quote]
2010 Subaru Impreza 5mt 5 door
