What the heck
The Scooby
What the heck
Post by The Scooby »
ok i thought it was a problem with my engine, now im certain its my turbo taking a crap.
when i first got the car, part throttle it would make a wining sound like a supercharger, but at WOT you just herd the turbo wistling. now it has the supercharger while no matter what throttle im at while boosting.
im going to try to take off my downpipe this week to make sure it is the turbo, because otehrwise its going into the shop on tuesday to have everything checked out.
people that have had their turbo fail, what where the symptoms you had before it finally went?
Thanks,
Shean
1986 GL wagon
EJ'ed and Lifted
Kelly
Post by Kelly »
Usually when turbos go, they either quit spooling, or start spewing oil. I seen em get out of balance so bad that the shaft bent, and the turbine fins were rubbing the housing making some pretty funky noises.
Almost sounds to me like a leak in the up pipe. Make sure when you pull everything apart, to inspect the gaskets and make sure no exhaust was leaking past them.
The Scooby
thanks kelly,
i was just going to pull the DP and check out the play of the shaft, but i guess while im at it ill check everything else out.
1986 GL wagon
EJ'ed and Lifted
mhrallyteam
Post by mhrallyteam »
I've seen quite a lot of broken up-pipe lately, on legacys and wrx. Mostly in cold weather regions, they crack just beside the weld.
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
The Scooby
ok but a leaking gasket or cracked up pipe wouldn't let the turbo spool at all, the intake is getting 10psi when at WOT, but you can tell its ether not getting 10psi or ive got a miss or something to that extent
1986 GL wagon
EJ'ed and Lifted
Penguin
Post by Penguin »
Hey Scooby,
what are you doing wednesday night? I can get you on the lift at 5 if it works for you. If it does I drink heineken ;-)
i got a few extra vf-11's and still have not messed with that up pipe... so either way s'all good. Maybe we should try an 02 sensor while we are under there.
-Penguin
1978 DL+GL 4WD Wagon (only ever seen 4!!!)
1993 Turbo White Wagon (EJ22t DOHC FMIC, 4.11 5 speed swap with wrx LSD)
1996 Impeza Outback Sport (wifes car)
2002 Suzuki GSXR-1140 Bored and Stroked
(just to much to list... 202mph on radar @ Daytona)
Project_Legacy
Post by Project_Legacy »
mine makes a turbo whistle too. last time i had it the problem WAS a small pre-turbo exhaust leak. i still boosted but not as much as i could have.
00 5MT AWD 2.5 RS - New Project
BAC5.2
Post by BAC5.2 »
How quickly does it spool? Does it perform as before, or worse?
The Scooby
thanks penguin, my car is in the shop right now, just dropped it off at superior automotive. if i get her back today sounds good to me, your just have to buy the heni because im only 19.
its spools normally, holds 9psi, which is where ive got it set at with the MBC. it never drops in PSI even when there is a drop in power.
1986 GL wagon
EJ'ed and Lifted
sammydafish
Post by sammydafish »
you sure it's not your tranny whining ... maybe even your power steering pump
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
Penguin
Post by Penguin »
lenny has the pad tonight, we are gutting a leg sedan and getting fugged up. And my wife has jury duty on wednesday so that is why it worked for me.
did you drop it off to see if steve and the guys can fix it?
-Penguin
The Scooby
penguin, sounds great... ya steve has had it since 8:30am today, and im still waiting to hear back from him.
Junior, no its not transmission, i know a transmission wine and this isn't it, also it has a rebuild transmission in it, and this sound goes away at WOT, and only happends when its trying to spool the turbo at partial throttle.
1986 GL wagon
EJ'ed and Lifted
The Scooby
penguin, just herd from steve, he is saying its a bad boost leak, sounds like its comming from the drivers side of the engine bay. so if you could help me find it tomarrow ill have the heni's with me.
1986 GL wagon
EJ'ed and Lifted
The Scooby
could it be a bad MAP sensor? not sensiong the correct MAP pressure and causing the ECM fuel cut?
or the EVAP canister being full of fumes and that venting to the engine under boost causing an overrich condition?
1986 GL wagon
EJ'ed and Lifted
The Scooby wrote:thanks penguin, my car is in the shop right now, just dropped it off at superior automotive. if i get her back today sounds good to me, your just have to buy the heni because im only 19.
What boost were you getting with the stock boost solenoid hooked up?
I get right at/around 9 psig of boost with the stock solenoid, and it doesn't taper off.
The Scooby
i dunno, havent ran it in a while now, it was only running like 7psi. 9psi at a few times
1986 GL wagon
EJ'ed and Lifted
The Scooby
finally, i pulled off my down pipe today to check out the turbo, has no shaft play at all. so then i decided to try plug wires and a coolant temp sensor, didn't have the sensor so i just got the wires.
seems to have fixed the problem. i switched back to my stock electronic boost controller and no problems, no miss, just go.
just want to thank everyone for all their help and ideas.
1986 GL wagon
EJ'ed and Lifted
