I need another engine section from an FSM. This one is a long shot though.
I need the engine specs for the EG33 from the SVX.
Standard FSM specs are what I need. Bore, stroke, rod and crank bearing journal widths, all that good stuff.
Anyone got it?
Need Engine Section of an FSM....
Bore/Stroke is the same as an EJ22, 96.9x75mm I assume the rod length is the same as all the other Subaru engines of the era, EJ22, EJ20, EJ22T are all 130.5mm rods.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
- quasi-mod-o
may want to check out www.subaru-svx.net/forum if you haven't already.
I need to do some research on the motor.
As much info as possible would be great! Head info would be nice as well.
I want to be as prepared as possible when I get into the project.
I also need cam specs and such.
It may "just" be an EJ22 with 2 more cylinders, but I want some real specs.
Top Secret. It will be something to be rekoned with though, that's for sure.
