so the compendium doesnt have any info for front wrx swaybar sizes. i have read posts that say the fronts wont work unless they are from a waggon. can anyone provide me with info on this? size of the swaybar on an 02 wrx waggon for instance as i have an good deal on one. so ultimatly will it fit on my 93ss?
also what is this measurment in mm, the diam. of the bar or what?
Front WRX wagon swaybar size?
NuwanD
believe it is 19mm (diameter)
Sedan has the wider track so the bar is probably too wide for our endlink mounting points
Make sure you get the bushings that go in the swaybar mount as well since the hole is 19mm diameter
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
1990 Rover Mini 1000
2004 Forester XT
subawhatsubawho
