'91 SS with KYB AGX--parts list
Completed OEM strut and spring changeout and installed AGX's with Whiteline "Control" springs. The rear strut top mounts, rear spring seats(perch) and the rear upper rubber seats needed to be replaced for the conversion, the other rubber parts were replaced because they were damaged. KYB AGX struts 734006(RF),734007(LF), 733010(RR), 733011(LR), www.performancepartsstore.com, $374.99. Whiteline Control springs, 70198(F), 70369(R), www.pdm-racing.com, $240.00. STi group N rear strut top mounts, ST20370AA240, www.rallispec.com, $110/pr. The following parts were sourced from www.subarugenuineparts.com,(thanks Jamie)--Rear spring seat(perch), 20373AA200, $36.64/pr. Rear upper rubber seat, 20375AA030, $19.86/pr. Rear lower rubber seat, 20375AA002, $14.88/pr. Rear helper(rubber bump stop), 20371AA041, $33.80/pr. STi group N front strut top mounts, ST2031055000, $113/pr. The old springs and probably the struts were the original OE, and the struts were very worn out, 178,000 mi. As a result of the new parts, the car is 3/4" lower, feels and handles way better, and I am very happy!
Good deal.
That's what I have....and it's a very nice handling car.
Prodrive are probably the best if you don't want a seriously low drop, but whiteline are the only ones that have wagon specific springs, so I'll probably go with them when the time comes.
185,000 miles
185,000 miles
Everyone has their opinion about springs. Rocket Rally has theirs. Why do they have this opinion, who knows? I used the Whiteline Control springs and lowered 3/4". They do have their Flatout line for some applications, which lowers more than their Control line. 3/4" is well within KYB's tolerance for lowering. I am satisfied with the results and don't expect any problems. H&R, Prodrive, etc. would have been fine probably, also. There are many others who have this combination(AGX/Whiteline) and like it. Cost and personal preference always play a subjective and or objective role in ones buying decisions. As long as you don't get to radical in your decisions, whatever product you choose will work out OK, most likely.
I have a '91 Sport Sedan, 5MT, which, of course has the turbo. The 91's have the more tapered top rear springs. The makers of aftermarket springs of that type is limited. I converted to be able to have more choices. I did chose Whiteline springs though, and they also make a spring for the '91 model year. In the future if I want something else I now have more options available.
Clarification - he had to mess with the mounts because he changed the springs - not because he put AGX in.
I've put AGX on stock springs in a variety of different types of BC BF, and never had to change anything else like top hats or perches or anything.
'00 Impr RS - sold
Oh...I didn't know that the '91 SS came with the tapered spring. The reason why I asked if it was NA, was because the Whiteline PN's he used fit a newer SS without changing the mounts etc., but an NA would need to be converted.rallysam wrote:Clarification - he had to mess with the mounts because he changed the springs - not because he put AGX in.
That is correct. It was because I did not want to use the '91 style springs that required the other parts. Other than that, I did want to use the STI Group N top mount. It took a lot of searching, research and study to figure out what parts I needed. The compendium of information is a start, but it does not provide crystal clear information that some of us feel we need.
You are asking me to remember something from a whole four months ago! Just kidding. I have to think about this. I threw away the old parts so can't go look at them. Am pretty sure of this info though. The original equipment rear top mount and and upper spring seats are integral(good word, huh) to each other. That is to say, the top mount and upper seat are one unit (attatched). That is why I used the parts as I listed for the conversion. For the conversion, the top mount is one piece and the upper strut mount(perch) is a separate piece. The top of the Whiteline Control spring is a larger diameter than the '91 OEM spring which required the upper rubber seat as listed, and the upper rubbber seat then nested into the upper spring seat properly. Does that help?
