I found a stock ej22t with 80,000 miles for 650...what engines are compatible to swap with my 91 awd turbo? and would they be any cheaper, or does any one know of 1 cheaper? (stock) (I've got blow by) : (
I'm also wondering what types of turbos are bolt on capable for my car if thats not a problem.
engine swap
That motor is what you need...good price too for that low of mileage
It'll just drop in
As far as turbos...any of the IHI VF series should bolt on...but don't just run out and get a bigger turbo without injectors, EM, Intercooler, Fuel pump, etc...
Do some searching...you will learn A TON!
It'll just drop in
