Attn Canadians-seatbelt ?
fngearhead
Post by fngearhead »
I've just done a seatbelt swap on my '91 sedan. YAY! no more motors. So, wondering if anyone could help me find a set of A and B pillar trims for the standard seatbelts, preferably grey. Any of you folks up north wanna go junkyarding? I scored a set of belts from an Outback. They fit almost prefectly. I had no idea how integrated those power belts were. Now just need to kill the flashing red light in the dash.
1989 Cherokee-lifted, locked and beat up
1991 Legacy L 5MT AWD with EJ20G swap SOLD... and rolled :(
1993 Turbo Wagon resurrected with '95 WRX guts
Fishy
Post by Fishy »
I know the yards around me here are pretty much useless but you might want to try searching http://www.car-parts.com you can select an area to search like Canada or western Canada or whatever. It will give you the name and contact info of the yard that has the parts too. Maybe someone from the board close to there could go check it out for you. :-)
94 legacy wagon - ej22T awd
99 legacy wagon - ej22 awd
HomeSlice
Post by HomeSlice »
to kill the flashin light jus jump the conectors in the a pillar. looks like a t
93BC"edm" 93GC 90BC R.I.P.
NuwanD
Post by NuwanD »
I have the trim but it's the SS gray, pm me if interested :)
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
1990 Rover Mini 1000
fngearhead
Isn't SS gray darker than the L gray? I'll keep ya in mind if I can't find any others.
fngearhead
Another question on seatbelts... Is the Canadian center console deeper than the motorbelt console? I'm assuming it is since mine has the belt retractors in it.
206er
Post by 206er »
fngearhead, can you describe how you swapped to manual belts? I HATE the automatics.
fngearhead
It wasn't an exact fit, but I used belts from an Outback, '97 I think, but probably any 2nd gen Legacy would work. I found that the buckles match perfectly with what's already in the car. I wasn't able to get a couple bolts to line up perfect, still need to do some very minor trimming and/or bending, but I did get all 3 major anchor bolts in securely. Those auto belts required me to drop the headliner and most plastic trim to remove them. You also need to lift part of the carpet in the rear footwell area to remove the existing lapbelt. The upper trim from dash to rear seat area no longer fits. The headliner was actually molded a bit different to clear the tracks. The belt indicator light in the dash flashes constantly now, but I'm going to trick the wiring to kill that soon. I got the Outback belts for $14 so really just time invested in this swap. Definitely worth it. Its nice to be able to put seatbelts on when I feel like it. But the reactions from my foreign friends were pretty entertaining.
Hmmm.....I really would love to get rid of the auto belts. Can you post pictures of the install? Did you take pictures with everything removed?
Regarding the seatbelt flashy guy on the dash. You can just unplug the autoseatbelt control unit. It's the rear of the vehicle.
http://www.surrealmirage.com/subaru/fil ... tion06.jpg
206er
Post by 206er »
do you think 2nd gen legacy trim bits will fit, because I dont want to have a hacked up looking interior.
ericS2the6
Post by ericS2the6 »
you'll need the upper and lower b pillar trims if you want to do it correctly, along with the a pillar trim. the lower b pillar trim sticks out a bit more at the neck, to allow the seatbelt to easily slide up and down.
also, to really complete the swap to factory level, you need a ca spec headliner. if you dont have one, the ca spec a pillar trim will not completely cover the cutouts in the us spec headliner.
Also, you will need to get if possilbe, ca spec seals for around the door opening. A custom job might be easier.
and like Josh said, just pull the little green box out of the trunk to kill the seatbelt light (and charm!).
fngearhead
I wanted to take photos, really should have. But everytime I grab my digital, the battery is dead and I just really wanted to get this finished. Its fairly obvious what needs to go though. Just remove everything that mounts through the headliner (grab handles, map lights, sun visors, dome light) all plastic trim (A-B pillar, door sills). Let the headliner drop down out of your way. Then get a 10mm and 16 mm socket and go crazy. There are 2 10mm bolts above the track partially hidden by the headliner. Those were fun to get at without mangling the headliner. The belts from a 2nd gen body will fit, but its not perfect. The anchors match, but I think I need to clearance maybe 1/8th inch off the edge of the retractor/body to make the 10mm alignment bolt line up properly. Any other questions, ask away.
jnorion
Post by jnorion »
Can you at least get some photos of the finished product at some point?
~Joel
IronMonkeyL255
Post by IronMonkeyL255 »
to kill the light, you can just remove the seatbelt control unit in the trunk, since they don't have to control anything anymore.
Rio Red '91 Legacy SS
Subtle
Post by Subtle »
The twgn I bought 3 years ago had the power seat belts and I couldn't stand them.
Got 3-point Cdn belts and plastic trim stuff from Saltair Recyclers on Vancouver Island.
These guys are honest and business-like.
Phone Ed at (250) 246-4675
or email: subaruman2003@hotmail.com
Honestly.....I don't really care about keeping the A-pillar trim pieces with the spots for the existing sliding tracks.....unless the piece I'm think of is built into the contraption.
Yeah....I'd like to see a finished product at least.
jnorion
Post by jnorion »
Legacy777 wrote:Honestly.....I don't really care about keeping the A-pillar trim pieces with the spots for the existing sliding tracks.....unless the piece I'm think of is built into the contraption.
That's pretty much what I was thinking too... as long as I can remove the actual sliding piece, I don't care about the slots. I'd rather just leave everything where it is and not have to try and match colors and stuff.
~Joel
fngearhead
I'll try to get some pics up soon. The A pillar trim only snaps to the body in one place. The other clips fit into the track. Now that its gone, the trim just hangs from the one clip down by the dash and bounces around. Canadian trims or mods are the only way to go. I pulled the wires on the belt controller and the little red guy quit blinking and as an added bonus, no more key beeps.
Hmm.....I wonder if you could remove just the part that the belt clips into, that way you could leave the track intact and keep the clips where they need to be.
fngearhead
The track covers the upper anchor bolt. I suppose you could cut the track and keep just what you need.
jnorion
Post by jnorion »
fngearhead wrote:The track covers the upper anchor bolt. I suppose you could cut the track and keep just what you need.
That at least sounds like the cheapest alternative, if not the best. That way all you need are parts available at the local junkyard. It might take longer to do, but no shipping from Canada.
~Joel
