Timing Belt Question
Manarius
Post by Manarius »
A friend of mine is pretty definite on picking up a 97L with a EJ22. Question: Timing Belt age is unknown. Car has 115k. Is it absolutely necessary to get that belt out now? Or is it worth waiting until it snaps then just replacing it myself?
And if I want to replace it myself, what tools would I need?
Binford
Post by Binford »
If you just wait till it snaps, somebody's gonna be stranded somewhere. Better do it now, IMO. I'd also do water pump and whatever seals are there. I didn't do any seals when I did mine, but I should've.
I think 97 is when the EJ22 became interference. If that's the case, you definitely don't want to let it snap!
sammydafish
Post by sammydafish »
vrg3 wrote:I think 97 is when the EJ22 became interference. If that's the case, you definitely don't want to let it snap!
yup, 97 was it, so you want to do it, plus make sure you do it right or turn key, smash motor
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
Manarius
Post by Manarius »
Are we absolutely sure about this? I wonder how a EJ22 can go interference?
I'm not absolutely sure. I'm pretty sure.
The interference is between the piston and the valves. The piston shape changed to increase compression, and so it's possible for the valves to hit the top of the piston when it's at top dead center.
Splinter
Post by Splinter »
Isnt any DOHC engine gonna be interference, since if the belt snaps the camshafts can rotate independantly, allowing the exhaust valves to contact the inktae?
This engine is SOHC.
Manarius
Post by Manarius »
I had thought that pretty much all EJ22E(apostrophe)s were the same. I know what interference is, but I thought that the engine stayed the same the whole way until it was discontinued.
Nope. See my posts in this thread.
free5ty1e
Post by free5ty1e »
's one of the reasons I'm hesitant to change the heads in my Leggy - I don't like having an interference engine of any kind.
Are all DOHC heads going to be valve-valve interference due to the potential independant camshaft rotation?
-Chris
91SS 4EAT stock, 200k mi
I do believe that is true of all EJ DOHC heads, yes.
Manarius
Post by Manarius »
Search of NASIOC came up with this....conflicting data!
NasiocGuy wrote: Has anyone out there had their timing belt fail on the 2.2L engine? If you have was there any valve/piston damage?
Lots of conflicting claims- from message boards, web sites, and dealers- that the 2.2L is or is-not interference type. SOA says this:
Dear Mr. :
I have consulted with our Technical Services Department who confirmed exactly what I relayed to you. I can offer you no more assurances than the fact that you have written Subaru Headquarters, I looked up the specifics of the engine on record, according to the VIN you supplied. According to our records, you have a 2.2 liter engine, 1997, which is a non-interference engine.
Best wishes,
Sandi Parente-Geiges
Internet Representative
Customer/Dealer Services
Subaru of America, Inc.
Responder wrote:According to the 1997 Technical Referance Booklet;
"Compression has been increased to 9.7/1 by reshaping the crown of the piston. This eliminates the clearance that was available between the piston at TDC and a fully open valve "
I have never seen a broken Cam Belt on an EJ motor. I have seen a few that changed timing because of tensionor or idler problems.
Maybe the change happened in different years for different models.
The car's owner's manual should specify the engine's compression ratio.
free5ty1e
Post by free5ty1e »
Yeah, when I had my 1999 Saturn, it was from later in the year and they made some big head changes, it caused lots of confusion when looking up and ordering parts.
I hate when they have two versions in a single year. Just ain't right.
-Chris
Splinter
Post by Splinter »
free5ty1e wrote:'s one of the reasons I'm hesitant to change the heads in my Leggy - I don't like having an interference engine of any kind.
If you wanted to be really adventurous, you might be able to build chain/belt sprokets for the cams, have the cams tied together with chains and drive them both with a single belt. I'd imagine that'd pretty much entirely get rid of the risk, since it'd be tough to break a chain like that
It'd be a hell of a thing to engineer though, for something that can be prevented almost entirely through regular maintenance.
Imprezive
Post by Imprezive »
If you let the belt just snap it wont only run you at high risk for killing your engine, but will most likely shatter the belt cover and maybe bend a cam gears.
My dad had a 91 loyale and when the belt broke it bent the right cam gear somehow. I know its 2 totally different cars but I dont see why that couldnt happen to you.
Don't be a slacker, replace the belt and feel secure.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Manarius
Post by Manarius »
But, I'd replace it faster if I knew I could do it myself. And if it's interference, I'm not going to do it myself. So, interference means a lot to me.
MikeC5
Post by MikeC5 »
Just because an engine is interference shouldn't scare anyone from doing a timing belt. Make sure you have the correct reference material for the car (factory shop manual is best), read it carefully and be sure you can find the timing marks. I prefer to lock the flywheel in place at TDC to prevent any accidental turning.
Post by entirelyturbo »
The 97 EJ22 is interference. Without a doubt.
Here is the EndWrench (Subaru's official publication for Subaru techs) that says so (the part that specifically says it is circled in red)
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
