Not that its annoying, it happens so rarely and for such a short amount of time that it took me a few tries to make sure it was actually happening
Just wondering if its a symptom of some other problem
Basically, in the half second or second between 6000rpm and the AT gear change (when forcing high changes by leaving the selector in 1 or 2), the headlights dim to about half voltage
Headlights dim near redline
BAC5.2
I second that. Check alternator belt tension.
My ALT belt was slipping bad, and under load the lights would dim.
Check that and see.
Check that and see.
If you find that its not the belt check the ground for the headlight. During High RPM you are requiring a lot of juice. If the ground is getting bad you might not be flowing enough for the headlights all the time. This can happen inconsistantly, wouldn't have to be every time you run the engine hard.
