Best performance tires for the money?
I'm going to be needing new summer tires soon and I want to get some goods ones, and the best bang for my buck. I'm looking for excellent dry traction with very good wet traction as well. I don't care about snow/ice/slush at all (I run winter tires on diffrent wheels). Any suggestions?
I also would like to know what sizes I can go with. I have the MY02-MY04 OEM 16" WRX wheels. 16X6.5. I want to get the widest tire I can while still staying with the OEM diameter. OEM is 205/55R16 TIA.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
Toyo Proxes 4's. I love em. They are also really cheap. Well under $100 each. Forester has them. Legacy will get them soon. Roman's SHO has them too. By far, the best budget performance all-season. I'd say get an all-season just because of the durability over summer tires.
they have them in 205/55/16. Diameter wise, 225/50/16 is the same, but strut clearance, I'm not sure if it'll work.
I'd say you should try it, but if it rubs, your in a pickle.
I'm happy with my Goodyear F1 GS-D3s. They're a little more expensive, but also have a better wear rating than most in this category. So, if you believe that, then they might be cheaper per mile. I've had my for 25k miles and they're not that worn.
For autocross, everyone seems to talk about Azenis.
Don't really have any first-hand experience comparing any of these, so take it for a grain of salt.
'00 Impr RS - sold
Sam - Ask Ed for a ride in his Miata when he has his summer Azenis on. That thing is sick. Those tires are +++. But I think they wouldn't last long under the weight of a Legacy.
I've been really happy with the GS-D3's.
They're pretty much down to the wear bars and have gotten harder.
I'll probably be getting another set unless I can find something better in a similar price range.
Cool, so either Toyo Proxes 4's or GY GS-D3's huh? Hmmm.
I can't really take chances with fitment. I need to know for sure what the widest tire I can run on the wrx 16's is.
Phil- You list a 225. Is there a 215?
I need to get on this pretty damn soon. My RE92's are so shot that I'm breaking loose at wastegate boost. That's just wrong.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
There isn't a direct fit 215 that matches the WRX OEM 205/55/16.
The Proxes 4 are available in that size though.
I run a 225/45/17 on the big wheels, and they don't rub the strut, but they do rub the fender slightly. With the WRX wheels being different width and offset, you might or might not make it.
I'd stick with a 205/55/16 for a 100% sure fit.
OK, the Proxes 4's sound like they might be the ticket. Thanks guys.
Phil- In terms of fitment. I could handle going to a slightly smaller sidewall with the 215 (wouldn't hurt performance any), I just don't want to go bigger.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
My NSX came with the Falken Azenis. Good tire for autocross & dry roads, but I wouldn't want to be on them in the rain. I have a set of Dunlop Direzzas that were $100 each in NSX size on the front now, should be a lot cheaper for Subie sizes. Check Tire Rack, Discount tire, Vulcan Tire, Edge Racing, and Roadway wholesale tire. You might find some good deals.
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
'05 Corolla XRS
I believe Vikash is running something like a 215/50 or something like that. That might be a good size to try, and I can't see any clearance issues. At the very worst, you might need to run a cheap pep-boys spacer.
A 215/50/16 is pretty close to stock diameter and only a little wider.
I bet those would clear just fine.
But a 215/50/16 is not available in the Proxes 4. A 205/55/16 IS, as is a 225/50/16.
I don't know that the latter would work without rubbing. It MIGHT, but I am unsure and I know your not in a position to "just try" it.
The 205/55/16's are $85 a pop + shipping from www.TireSwap.com
Good guys to deal with too.
I've been pleased with them in ALL conditions, including gravel.
I might get a set of 225/50/16 for the Outback wheels so I can use the Legacy in the winter if necessary. I'd be curious how the 4's would handle the power, but I imagine it'd be fine.
At the Baltimore Int'l Auto Show, most of the modded aftermarket cars were using Proxes 4's for the show.
If they can make a 3500lb Ford Taurus be a monster in the snow, they can do woners for something 600 pounds lighter.
OK, so I started looking into tires and I've narrowed it down a little. I'm broke, so I'm looking to go cheap.
Anyone know anything about the General Exclaim UHP? They are one of the highest rated tires on tirerack in the size I was looking for. They happen to be just about the cheapest too!
http://www.tirerack.com/tires/tires.jsp ... s&place=18
That or I was thinking about going with the Kumho Ecsta SPT. They are also cheap and rated pretty well.
http://www.tirerack.com/tires/tires.jsp ... s&place=19
Any thoughts?
Any thoughts?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
I saw a set of the new General tires and they looked pretty good!
It looked like treadwear would suffer though. Seems like they sacrificed durability for high grip (using very soft compound). From that, I'd guess that the tires would feel kind of "floaty", espically based on grabbing the sidewall and trying to flex it.
Seemed like they were worth the money, and that you could run them at a higher-than-average PSI and that you'd be OK.
i have been pretty happy w/my kumho ecsta supra 712s but i think they are being phased out. they are a prettyold design. good summer only tire for the money. not great. just good. and untill you get into the 17 and up sizes they are around 60-80 dollars.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
What do people think of the Kumho Ecsta ASX? It's ranked 5th on TireRack and is cheap (only $73 per tire). I might eventually get them to replace the RE92s on the WRX wheels I'm getting, but I'd like to see if anyone has any feedback first.
-- David
1990 Subaru Legacy L+ 4WD Wagon 5MT, white with 66k miles -- SOLD
[url=http://www.g20.net/forum/showthread.php?t=66214]1992 Infiniti G20 5MT[/url], White Sandstone with 175k miles
