Oops - loosened head bolts instead of valve cover bolts
schspeedster
I win the Darwin award for stupidity - am used to GM motors with bolts around the valve covers, didnt notice the real valve cover bolts, and loosened the head bolts on my 2.2 N/A. No wonder the bolts were so tight. Since the head wasn't actually removed, do I now have to loosen all the head bolts and re-torque step-by-step like in the Haynes manual?
- quasi-mod-o
How many did you loosen? Most of the head bolts are under the valve cover, so losening the ones that are exposed really shouldn't do any harm as long as you torque 'em back down. I think you'll be fine. If you're turboed and have your boost turned up, that may be different. My .02.
schspeedster
Only the 6 on each side, around the outside of the cover. This is a N/A motor.Binford wrote:How many did you loosen? Most of the head bolts are under the valve cover, so losening the ones that are exposed really shouldn't do any harm as long as you torque 'em back down. I think you'll be fine. If you're turboed and have your boost turned up, that may be different. My .02.
sammydafish
huh? all 6 head bolts are exterior to the valve cover.Binford wrote:How many did you loosen? Most of the head bolts are under the valve cover, so losening the ones that are exposed really shouldn't do any harm as long as you torque 'em back down. I think you'll be fine. If you're turboed and have your boost turned up, that may be different. My .02.
if you lostened them all the way and the head moved, you're scrwed, you need to replace the gasket. If the head didn;t move, you might get away with torquing them back down. Make sure you do it in the right order and the right procedure (there's a lot of back and forth on subaru heads) This isn't the right way to do it, but you might be ok. worst comes to worst, you need to do a HG job, so no matter what you're no worse off for trying.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
There are no bolts under the cover? I've never had the valve covers off an EJ before, I'm sorry. I did a quick scan of my engine and thought most of the bolts would be under the cover. Assumptions made as ass of me today.
Just for reference - http://www.thawa.net/gallery/EJ22ESwap/valvencam , that's a EJ22E (non turbo) with the valve cover off.
I've never taken the heads off but from listening to others on the boards, you can reuse the head bolts once, maybe twice. So yeah, torque them back and hope your gasket stayed seated.
Lee
schspeedster
Didn't loosen all 6, so if I do it by the book (loosening all 6) that increases chances of the head moving. Don't think it moved at all just have to get the bolts back to original torque.sammydafish wrote:huh? all 6 head bolts are exterior to the valve cover.Binford wrote:How many did you loosen? Most of the head bolts are under the valve cover, so losening the ones that are exposed really shouldn't do any harm as long as you torque 'em back down. I think you'll be fine. If you're turboed and have your boost turned up, that may be different. My .02.
sammydafish
yeah, I would retorque the ones you lostened in the order they need to be torqued in, just skip the ones you didn't losen.... good luck
- Junior
Matt Monson
- quasi-mod-o
IMO,
This is just a recipe for future disaster. Got get new head gaskets, reuse the head bolts and remember the cardinal rule of "do it right, once"
Also, I would be very wary of just retorquing the loosened bolts and leaving the others tight. The reason there is that multi-step process is two fold. It is partially to compress the gasket and partially to provide even clamping. If you do it unevenly (with two already all the way tight) I would be worried about warping the heads. These heads warp more easily than most people realize...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
sammydafish
I really wouldn't worry about warping the heads. These are some pretty small heads, not an inline 6. The torque sequence is for proper gasket compression and because of the bolt design. Loosening and retightening bolts is a common procedure on any engine with really long head bolts. I assume it's to ensure the turning of the bolt is applied to the torque on the threads, not lost in torsional flex.
have you tried to just torque them down again yet? Did your head gasket survive?
- Junior
schspeedster
schspeedster
Retorqued all 6 on one side so far. Did some research, and found retorquing heads on the old Subaru EA-series, VW, and other motors is recommended procedure. That would make sense to maintain the clamping force, since bolts stretch and gaskets squish. Maybe heads on EJ-series motors could use retorquing periodically too?
Before a million internet parrots tell you to change the gasket realise this... If it's an MLS gasket it's not uncommon to re-use the gasket anyway. It's very common to double torque head bolts on performance engines anyway. I've done it dozens of times with 0 issues. I've never re-used a gasket but know dozens of people who have with 0 problems.
The main concern I would have is warping the head because of the uneven clamp load. Chances are very good that you can just torque things down and be just fine.
On one of my engines I once forgot the dowels. I just removed the head, installed them, re-torqued everything and proceeded to run 15 PSI of boost all day long.
-Michael
-Michael
Matt Monson
- quasi-mod-o
I take it you have never actually removed an EJ22 head gasket? There is no way in hell that gasket could ever be reused. They tear up and get shredded to pieces upon removal. I have never worked on any other engine that requires so much head and block clean up before reassembly with new head gaskets.hackish wrote:Before a million internet parrots tell you to change the gasket realise this... If it's an MLS gasket it's not uncommon to re-use the gasket anyway. It's very common to double torque head bolts on performance engines anyway. I've done it dozens of times with 0 issues. I've never re-used a gasket but know dozens of people who have with 0 problems.
-Michael
I too have retorqued the HG's on other Subaru motors. When we did the high compression frankensubby, the car's owner installed the metal STi gasket backwards and that messed up some coolant passage alignment. I just had him remove it and start over from the beginning. And when I was playing with Hondas, we used to reuse copper head gaskets all the time...
Suby Hai!
Suby Hai!
As I have said I've never personally re-used a gasket on a customer's engine. I've removed the gaskets on EJ22T, EJ20K and EJ25. I've never seen one shred upon removal. From what I remember they were all MLS as well.Matt Monson wrote:
-Michael
Matt Monson
- quasi-mod-o
That's what I am getting at. I have never seen an Ej22 or Ej20G from any of the '89-94 cars have an MLS gasket. Modern EJ20, Ej22 and Ej25's yes, but the early cars all have a composite gasket of some sort. See pics of Ej22T below:hackish wrote:As I have said I've never personally re-used a gasket on a customer's engine. I've removed the gaskets on EJ22T, EJ20K and EJ25. I've never seen one shred upon removal. From what I remember they were all MLS as well.Matt Monson wrote:
-Michael
You can see all the crap the gasket left behind on the block. The gasket is still attached to the head in pic #2...
Suby Hai!
Suby Hai!
Marine manifold gaskets make old Subaru HGs a dream.
I wouldn't worry about the HGs here as he didn't separate the heads.
sammydafish
werd... you can reuse an MLS gasket... unfortunatly, the EJ22 doesn't come with one
- Junior
sammydafish
schspeedster
