Success!!!! I decided today that I was gonna get this sway bar on if it cost me my life in the process. I lifted my Legacy up and went to work. I lubed that baby up with "liquid wrench" and started torquin'. I again went with a previous suggestion of using the floor jack for power and set the combo wrench in place. I layed into it with the floor jack and the wrench and it finally broke free (it literally sounded like it broke). Those bolts were on soooo tight that it took a couple of times with the jack and everytime it sounded like something was snapping.
After that madness I realized, as I began to pull the main bolt out, that its a little tight underneath the car to try and pull a 10 inch single bolt out. I instantly found that I couldnt make it past the spare tire housing. So I just decided to bang on it with a hammer a bit and make a dent for clearance. It worked fine, but then on the other main bolt I couldnt make it past the muffler. I ended up having to pull the rubber mounts around the muffler off and lowering the whole end of the exhaust system in order to pull the other bolt out. 10 inch bolts in that area of the car are a pain!!
So I finally got the control arms in and eventually the sway bar, but it was a long painful process.
Total time today: 6 hours
Results: I took it for a test run after install and I was very satisfied. It handles like a new car. Its gonna take some getting used to because I'm not used to the back end being so responsive with oversteer. Its even more fun to drive now
Pnuematic(sp) tools rock, and in some cases good old fashioned wrenches rock even more.
Thanks for all the input guys, and gals. You've all been a great help.
