measuring an external wastegate
when they say a wastegate is 45mm, what exactly are they measuring?
///M
'93 Legacy SS - part out
I'd imagine it's plunger diameter.
Smaller wastegates are for high-boost. Larger wastegates are better for lower-boost. That's what Turbosmart says anyway.
Look at their catalog. You should be able to ID it from it's features (cap and flange style, 2 bolt or v-band).
May be a knock off then. They never made a 38mm progate. They made a 38mm Ultragate, which is styled like the TIAL. I see lots of 38mm 2-bolt gates on e-bay that look like the progate.
The Progate is ONLY available in a V-band.
