On to my question. When i had purchased my car about 2 months ago it was a 2WD and AUTOMATIC. Only reason i purchaced this car out of all the other i had seen was cause it had a sunroof
So i converted it to AWD manual with the help of this site:
http://www.surrealmirage.com/subaru/subaru.html
From reading on this board i believe it is someone from this site. I would like to thank you for making this conversion very stress free and giving me something to refer too at times of great need. Great job!!!
Converting her took me 3.5 days... would have been longer if it wasnt for that site... all those contemplating the conversion, JUST DO IT! VERY VERY WORTHWHILE!
My question is, I has been threw many fourms and been to that site over and over again and i cant seem to figure out the AT/MT ID!
It seems it might be wired backwards (as the website explains) but it seems as the the donor car doesnt even have that pin grounded... Both ECU's are exactly the same and both are missing pin 20 on connector B48 (on the connector that is... the pin is still on the ECU) I believe that there SHOULD be an ID because the car doesnt seem to run the way it should. It backfires alittle on gearing down and seems to misfire and higher speed between 80 - 120 km/h
Sorry for the long post but i just want to get to the bottom of this and drive the her like she wants to be driven!!!
Looking foward to joining such a great community and hope i can do my part on giving a hand when i can!
Regards, Sam
