Need more torque, what can I do?
RallyRS
Post by RallyRS »
Hi,
I race my legacy in rally and its bogging in tight corners. I'm trying to left foot brake to keep boost up but not going so well.
I have replaced the air box with a pod filter and run a 2.5" mandrel bent exhaust with no mufflers. Maybe this has lost me my torque? Seems to be dead below 3500rpm.
I have a VF8 turbo and it hits boost around 2500.
I also use a eprom chip in standard ECU which seems to run abit too rich everywhere, I think it might be getting to much fuel sometimes???
Close-ratio box, anti-lag and stand alone ECU would help, but I need some more cost effective options.
Cheers
Hayden
Project_Legacy
Post by Project_Legacy »
my car also seems to run a bit too rich in all rpms, and mine does like to bog down also. i think u should check into that.
i dont think there is any way to up your torque without spending a lot of money.
as you said, you could do these
but that would all be expensive IMO. sorry i couldnt help ya any more.
00 5MT AWD 2.5 RS - New Project
BAC5.2
Post by BAC5.2 »
Want more torque, up the boost.
Project_Legacy
that wouldnt help much with low-end torque would it? i think thats what he wants. maybe im wrong. :?
jnorion
Post by jnorion »
When you remove stock, restrictive intakes and exhaust, you usually sacrifice low-end torque for more up top.
~Joel
BAC5.2
Post by BAC5.2 »
I don't think freeing up the intake or exhaust really hurts low-end torque on a turbocharged vehicle. I think it just increases top end, and the change makes the bottom end feel like it lost power.
douglas vincent
Post by douglas vincent »
IF you are running too rich down low, its a definate power killer.
jnorion
Post by jnorion »
BAC5.2 wrote:I don't think freeing up the intake or exhaust really hurts low-end torque on a turbocharged vehicle. I think it just increases top end, and the change makes the bottom end feel like it lost power.
I actually wasn't even thinking about turbo... that makes sense.
~Joel
Post by 555BCTurbo »
jnorion wrote:When you remove stock, restrictive intakes and exhaust, you usually sacrifice low-end torque for more up top.
Incorrect
If you do a lot of corners at relatively low speed, might you do better with a more spoolable turbo? A VF10 or TD04, for example?
douglas vincent
SupaChaga!!!
Kelly
Post by Kelly »
What you suffer from is small displacement. I hate the 2 litre. Im forced to drive USDM WRX's all the time, and I just want to vomit all over them.
You need ignition timing my friend. Thaty'll gain ya some low end and spool up.
rallitektech wrote:What you suffer from is small displacement. I hate the 2 litre. Im forced to drive USDM WRX's all the time, and I just want to vomit all over them.
2 Step limiter what?!?
Manarius
Post by Manarius »
Buy a new engine.
Really.
No replacement for displacement.
RallyRS
Post by RallyRS »
Thanks for your tips! All useful apart from new engine.
I think there is no cheap/quick answer. I need to get the wallet out and spend some money, again!!!
I good tune on a 4wd dyno with a stand alone ECU would be best I think??? maybe some anti-lag. Practicing my left foot braking everyday so that is alway hoping.
Better start saving.
Thanks for your help.
Hayden
