96 geo prism CEL
magicmike
96 geo prism CEL
Post by magicmike »
Well my g/f has a pretty shitty 96 geo prism. she has been complaining about hesitation when she is getting onto onramps etc. today she went around a corner and tried to accelorate and the car hesitated and the CEL started flashing then eventually turned solid. My question is: is there a way to read codes like on our cars? Any help would be good, thanks in advance.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
I believe everything in this post to be true, but I'm not 100% sure of it.
Your girlfriend's Prizm is essentially a base model Toyota Corolla.
The only way to read trouble codes from this car is with an OBD-II scantool or a Toyota factory scantool.
A flashing OBD-II CEL means heavy misfire (with the potential to damage the catalytic converter). I would imagine that the trouble code stored is a misfire code. The code(s) encodes which cylinder(s) are involved.
Is she low on fuel? The fuel pump is on the right side of the fuel tank, so right turns could make all the fuel slosh away from the pump if the tank isn't full. Onramps tend to be long sweeping right-hand turns. Fuel starvation would cause misfires. This could be aggravated by a partially clogged pump sock or a pump that's on its way out.
magicmike
Post by magicmike »
Thanks Vikash for chiming in. The fuel question was the first one that I asked. This morning was the worst episode and it was on a full tank. I was going to do a quick tune up tomorrow for her (plugs, wires, air filter, fuel filter) and see how it runs. If your sure you only get a flashing CEL with a misfire then I will tell her its ok to drive it to my condo (half way between us) and I'll do a tune up tomorrow. Let me also add that the car has about 130k miles on it and she bought it with about 70k miles and never did any tune ups, just oil changes.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Sounds like plug wires.
The older Geo prizms were even worse.
Yeah, sounds like the whole ignition system could use a going over... Doesn't explain why it happens only at corners, unless those are the only places where she opens the throttle enough to produce enough cylinder pressure to create the msifire condition.
I am pretty sure the flashing CEL means excessive misfire. Note, though, that the reason it flashes instead of just illuminating is that it's supposed to convey urgency since the level of misfire is supposedly enough to cause damage to the catalytic converter.
magicmike
Post by magicmike »
ok well changed out the air filter, pvc valve, plugs, wires, cap, and rotor. The plugs in there were a/c delco gapped at .050" or should I say worn to .050". reset the ecu and it was running great. Thanks for info...
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
Yay.
Hah! 0.050"? The specified gap is 0.031"!
magicmike
Post by magicmike »
hum, I couldn't find the gap in the owners manual so I just left them at the .040" that they came gapped as. Should be fine, shes not running a turbo in that thing lol.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
I was just going by the chart in the Chilton's manual from AutoZone's web site:
http://www.autozone.com/images/cds/gif/ ... 169b00.gif
