are flywheels different between push and pull type
azn2nr
Post by azn2nr »
well are they. i cant seem to be able to figure it out
can i use a wrx flywheel on a impreza L trans??
-jason
Post by 555BCTurbo »
I don't believe they are. :smt069
DLC
Post by DLC »
I've heard that they are. Call up someone that knows for sure, like Richard Buckner at Royal Moore Subaru: 503-615-8403
Legacy Central
Project_Legacy
Post by Project_Legacy »
did anything happen with this? is your impreza L a FWD?
00 5MT AWD 2.5 RS - New Project
The flywheel itself may be similar. I don't know for sure if they are exactly the same.
But the big thing here is that if you want to use a WRX flywheel, I'm pretty sure a standard impreza L pressure plate won't bolt to it. and a WRX pressure plate won't work with a push type clutch configuration.
napphappy
Post by napphappy »
Legacy777 wrote:The flywheel itself may be similar. I don't know for sure if they are exactly the same.
Ditto, The bolt holes for the pressure plate dont line up.
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
Project_Legacy
yea i figured that would happen. i have the stock L FWD tranny that i will be using, and am trying to find clutch/flywheel setups i could use... its turning out to be rather difficult..
