I was planning to do the install with help from a friend, but took it to Midas instead. Good choice in the end since Midas has a flame wrench and I don't. It sounds really good, nice mellow rumble. I was expecting it to be louder than it is, but I'm glad to err on the quiet side. It rumbles nicely below 3000 revs and is barely noticeable at 75mph.
Is it worth pulling the smaller cat to try and liven up the old N/A even more? Not looking to get obnoxious, but now that I'm making noise I want a bit more.
Dynomax turbo muffler installed
1989 Cherokee-lifted, locked and beat up
1991 Legacy L 5MT AWD with EJ20G swap SOLD... and rolled :(
1993 Turbo Wagon resurrected with '95 WRX guts
On N/A engines greater power can be obtained with minimal ( ie zero) back pressure.
By tuning the lengths of the exhaust stacks an "extractor " effect comes in.
If somebody is burning valves they are running too lean. If you want to push the lean use titanium or sodium-filled valves.
these are the key words here. Backpressure increases pumping losses which is bad on any engine. Engines will always make more peak power with less backpressure. Often N/A engines will loose low end torque when opening up the exhaust. This is due to loss cylinder filling during the overlap phase of the cams. Proper adjustments to cam timing will fix this. The engine operates as a complete system, changes to one part must take into account the affects on the other parts. WAY to many people don’t grasp this concept.realfinn wrote: with the wrong setup.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
