cant get more boost
aderiley
cant get more boost
Post by aderiley »
ok guys/girls could do with some help. i have fitted a gfb reactor dual boost low boost set to 11psi but no mater how much i adjust the gfb i cant get high boost over 12.5psi i have no sudden cut out or detonation any ideas also what coolant should i use in the intercooler. spec = uk 95 ej20 vf8 turbo 38mm vent to atmo bov (new but cheap from ebay) rising rate fuel regulator, greddy cone filter water charged intercooler running 97 ron fuel, i have an fcd but havent fitted it yet as i understand fuel cut comes in at 17psi i dont know how much it would have boosted before i fitted the dual boost cant here signs of wastegate flutter. a thought i had was that i was using the factory bov before but still got the whoosh, could it be that there is another bov fitted somewhere else (ie near intercooler) have had a quick look but cant see one where could it be if there is one and surely it would allow me over 12.5psi. help! :(
94 20lt turbo est
Maybe your cheap-from-eBay blowoff valve is leaking boost?
aderiley
Post by aderiley »
i was wondering that as well cant hear any leakage but may have to try and borrow another to try
94 20lt turbo est
You could try just capping the blowoff valve off and going for one very careful run where you gingerly operate the throttle without rapid movements.
Psychoreo
Post by Psychoreo »
^good idea. And love the new Icon vrg3!!
Just be VERY careful with the throttle. I'm assuming you have a boost gague, as you can see how much you're boosting. Maybe the boost gague is reading wrong aswell?
stupid electrical work...
I didn't pick it; nor do I particularly like it.
aderiley
Post by aderiley »
good plan bov came with packing washers have added a few but no difference so maybe load up a few more or cap it and keep my eye on the boost guage
94 20lt turbo est
