I could take it to a local shop, but then it wouldnt really be MY project, yanno?
I will of course compensate you for time spent, food and board
Im NOT rebuilding the engine for the new pistons at this point, Im going to give it to a shop for that.
This is what I will be doing:
Entire exhaust from the crosspipe back to the tailpipe, including STi turbo
RS2.5 SOHC heads + manifold
550CC injectors
Autronic SMC ecu
MSD MIS2 ignition
Decent sized front mount
Hotbits struts (I may get the shop to do this, depending on the situation)
Intake
5MT+rear diff swap from forester (4.44 ratio)
Possibly alcohol/water injection
If theres anyone in BC who can help me out, that'd be ideal, but I'd be prepared to drive down to the Seattle area as well.
