Anyway, I have a free non-ABS hub in the Tacoma Washington area. If you want it let me know, only cost is getting it to you (shipping). If your in the Tacoma area It'd really be free...
Free right front no-n ABS hub
I finally got an ABS equiped hub to replace the non-ABS hub the PO had installed. It was a pretty easy swap, even figured out why teh alignment shop couldn't get any adjustmaent out of the right front corner. It had 2 small shank bolts installed, instead of 1 small shank and the eccentric bolt
!!! Less than 2 hours (including junkyard time) and my ABS light stays out now
