Compression Check Specs
I am curious what a healthy EJ22T block should show on a compression check... i searched and searched and couldnt find numbers for what they should be.
Here is what mine looked like-bone stock in my impreza, a 1993 motor, no idea how many miles on it, but most likely lots.
1: 135 psi
2: 140 psi
3: 142 psi
4: 150 psi
Thanks for the help.
1: 135 psi
2: 140 psi
3: 142 psi
4: 150 psi
sammydafish
It's not so much a matter of how much pressure there is, but more the ballance. The pressure can change a lot depending on how you do the test. The proper way would be to pull all the plugs, disable the fuel system and do the test dry, then squirt some oil in the chambers and do it again wet.
You numbers are within 10% of each other. Although 135 is mildly low, I wouldn't be concerned, if you didn't disable the injectors is might have just gotten a little washed.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
- quasi-mod-o
Just disconnect the fuel pump, it's easier than disconnecting all 4 injectors.Threshld1 wrote:is pulling the injector connectors good enough or should the pump be disconnected and pressure relieved?
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
- quasi-mod-o
That's perfect. Your engine is as good as new.
