Finally swapping to manual!?!?
I've been dancing around this for a while, but it seems that I may now actually have the opportunity. A friend of mine has a manual from a '95 or '96 Legacy. My question is, what parts will I need to do the swap other than the tranny itself. I am currently in a '94 SS 4EAT.
gt2.5turbo
ya read the write up and it will tell ya everything you need and has a big part list
93 White Legacy Turbo Wagon: For Sale-ish
93 White Turbo Sedan: soon with a little more umf
91, funky brown purple gray color, legacy L Wagon: the "its so cheap i cant not pass it up" purchase to get me around when the others are down
[quote="shemoves"]I'll check it...quick question. Is it possible for me and a friend to do in his garage?[/quote]
If you can handle changing out a tranny, you should be able to convert AT to MT. There isn't much more to it than swapping the tranny. Pedals and shifter are very straightforward.
http://www.surrealmirage.com/subaru/swap/swap.html
Here is Josh's writeup. Good Luck. Feel free to pm me if you have any other ??s. I'm in the middle of swapping mine today.
Stephen
Stephen
I did mine in an exposed driveway with a pretty good slant to it in the middle of january in 20deg.+high winds, with a floor jack and bolted to it a custom made tranny cradle. had help pulling the 4eat but installed 5mt by myself. went pretty smooth, just time consuming with no air tools.
