can i reuse a up pipe to turbo gasket?
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
You can reuse the gasket if it looks like it's in okay shape and you're using an uppipe with a flex joint. If it's corroded or bent or anything, or if you're using a cheap aftermarket uppipe, I would buy a new gasket.
Especially if you're reusing it, I would recommend giving it a few coats of copper gasket spray on each side. That stuff is amazing.
