I checked and they weight 19.3lbs each. Which is around 3lbs heavier than stock, and the bigger rubber needed is 23lbs each.
So...42.3lb each
So first off I am worried about clearance, which I think I can deal with after rolling the fenders and getting stiffer springs and cutting the original spring perch off my wrx struts when I put the Ground Control coilover kit on it. But I don't know if the weight increase is worth it.
What do you guys think? Should I got for it?
