intake manifold discussion.
azn2nr
Post by azn2nr »
i remember some talk about manifold swaping a few years ago. bascily from what i remember the talk said its impossible. well after taking a look at pictures of a 22t manifold and looking at a few other physicaly it is my contention that wrx manifolds do fit on our heads. the bolt pattern seems to be the same.
if anyone has info to deter or prove me wrong then please post up
-jason
napphappy
Post by napphappy »
Im pretty sure there is a post about this here somewhere.
I think it said that the WRX manifold was too wide.
Did you search?
1997 White BG Ltd 5MT, EJ22T with Wiescos, EJ20R Heads, Two large dents R.I.P
1995 Impreza EJ22T DOHC Hydra EMS, 20g, EWG, 3in APS TBE, AWIC
sammydafish
Post by sammydafish »
I have a 2000 EJ25 manifold here and it doesn't fit. The ports and bolt spacing are bigger than the EJ22. It's the same shape, just bigger. It won't fit.
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
Matt Monson
Post by Matt Monson »
There are two different offset bolt patterns. There is the the early one that was used on Ej18's and the Ej22 variants. Then there is the late one that started in '99 and is used on all post '99 SOHC Ej25's and Ej20's. As Sammy said, the spacing is larger.
The third pattern is the inline pattern. This was used on Ej20's starting in '89 and continued through '98. It is also the same as used on '96-99 DOHC Ej25's...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
dzx
Post by dzx »
I have a wrx intake manifold laying around and it doesn't fit on the ej22t heads.
///M
'93 Legacy SS - part out
