when i make hard right turns the rear inside (right rear) tire squeals very easily and i get what can best be described as wheel hop.
this does not happen when i turn left
that right rear strut is totally blown and covered in oil. i am assuming that is the problem.
however, the rear most lateral link on that side is bent where the sway bar endlink attatches.
the car drives straight and the wheel appears to be properly alligned.
inside rear tire hoppin' and squealin' on rt. turns
greg donovan
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
greg donovan
How is the lateral link bent? That could be the problem.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
greg donovan
it is bent up a little right where the swaybar mounts.THAWA wrote:How is the lateral link bent? That could be the problem.
the thing is that i am pretty sure it has been bent for a while and i just noticed this happening this spring. and there has been no unusual wear on the tires.
the car has a recertified salvage title becuase the first owner put it into a ditch that had some water in it and his ins. company writes off anything that touches anything bigger than a deep puddle.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
greg donovan
greg donovan
well,
i decided i better check my tire pressures.
turns out they were all around 26.5 psi.
bumped them up to 33/32 f/r.
that seems to have cured the problem.
i think the combination of a blown strut and low tire pressure were the problem.
i am going to get my alignment checked next week.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
greg donovan
