Oil pans, $35 delivered
Blackbart
Vendor
Vendor
Post by Blackbart »
I have a few oil pans that fit the ej22, ej22t and ej25, $35 each delivered. Includes oil pickup if needed.
dscoobydoo
Post by dscoobydoo »
I might want one. Any chance you have a picture of the engine with the pan pulled so I can see clearance. ( this would be for adding an oil temp sensor in the pan)
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Blackbart
Vendor
Vendor
Post by Blackbart »
The motor is out of the car, is there anything I can measure for you?
dscoobydoo
I need to know what the clearance is around the pan(between the pan and oil pickup and crank), so I know where to tap into it for the oil temp sensor.
05 GD-STI
00- GF
