Needed 2 good pistons
anyone have 2 good EJ22 NA pistons they don't need? I think I might just throw my old engine back together with two used pistons and boost it some more until I really blow it up. All I really need is a pair of pistons... so who wants to help me out?
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
Finaly cleaned off the block, I need a pair of B size pistons if anyone has em. Maybe even a full set as it's likely inevitable that I'll break some more as time goes on
- Junior
oh yeah, I need to replace the 2 and 4 pistons, so if I oonly get two, I need two left side pistion.
- Junior
anyone have a set of NA pistons? I'm not sure that I'll be able to use the turbo pistons, they might drop my compression to much. Great for giant boost, but I'm not to sure I wanna do that, kinda wouldn't mind some killer fuel economy right now.
BTW, I'm using EJ25 SOHC heads, so the compression would be around 8:1 with turbo pistons and those heads.
- Junior
