Will a '06 STI fuel pump fit my 93 ss
smh0101
Post by smh0101 »
Hey I think my fuelpump is out so will a 2006 fuel pump out of an sti fit in my 93 ss?
This guy on Nasioc is asking 20 bucks shipped.
mhrallyteam
Post by mhrallyteam »
I use a 2004 STI pump in my legacy, same shape, size.
92 l swapped to ej22T with 2.0T shortblock
4.111 manual 2.5RS tranny, sti eng mount, wrx I/C, MBC, WRX turboback exhaust, WRX front seats, STI rad cap, WRX specR1 struts, Eibach springs , leg turbo front brake, WRX rear brake.
Post by 555BCTurbo »
The STi pump actually flows less, but yes it will work, and the price is right so go for it!
smh0101
Post by smh0101 »
If an sti is higher performance why would the pump, pump less? Would/could this effect gas mileage?
mhrallyteam
No, it won't affect fuel mileage, the pump gives the system a pressure and then the injection system uses what it need for the power asked. The fuel pump on more recent subaru works at different speed rate where our old system make the pump work at a constant speed, if i remember correctly.
You just have to make sure that your system never lack fuel, and it wont with a sti pump.
