WTB: All parts to convert 92 Legacy wagon from air struts
handson
Post by handson »
I need to convert my new 92 Legacy wagon from air struts to conventional struts.
Basically, I need all the pieces.
The sooner the better. I had just got rid of my 91 Turbo, and I got a great deal on this 92 wagon with 65K on it because the struts are DOA.
Thanks!
handson
Post by handson »
What fits? what setups can I use?
DLC
Post by DLC »
You need the strut, spring, top hat and top mount. If you want to use used parts, simply go to a salvage yard and purchase the entire assemblies from a 92-94 wagon and swap them in. If you want to replace the struts with new units, get everything anyways, and swap the struts.
You can use later model Legacy and Impreza parts, but you'd be better off with near-year parts.
Legacy Central
handson
Post by handson »
Would a set from a 95 wagon fit?
DLC
Post by DLC »
It should fit, yes.
Legacy Central
