Manny
my3awds wrote:Well, opening exhaust flow by deleting a cat or any performance modification these days can be considered an emissions issue and therefore illegal, but people still do it.
The only vacuum lines I wanted to remove were the emission lines, the ones that put oil or extra exhaust gases in your intake track. Again, coming from the dsm world, I've done this without any adverse effects (except for maybe the environment) and it has helped especially when you have a bit of blowby. This is why you see pretty much 0 vacuum lines on race setups. BUT, since the ej engines are designed differently I thought I'd ask just to be sure. Thanks for the warning.
