CPC Solenoid Valve, for a '92 turbo ss, easy way to replace?
Ok gang, here it is. Ive found pleanty of info on this little sucker as it seems to go out on just about every early model turbo legacy. If you need clarification, it is the solenoid that causes a code 35. What Ive not found on this board is a trick for replacing this part without removing the intake mani along with the overwhelming mess of hoses, vacume lines etc.. If anyone has a trick to get at this silly part without hours of agony please feel free to enlighten me. Ive messed with it for a couple of hours and my unimaginative brain hasnt come up with a solution. If I missed somthing obvious in an archive, I will gladly own up to my lack of persistance and dig further. Thanks in advance, as allways your assistance is very much appreciated.
1992 SS 5MT
Project_Legacy
code 35... i thought that was the purge control solenoid. its the one that is under the intake manifold on the passenger side correct? yea its a little bitch to get to. you CAN get to it without removing anything else. a friend and i did it, just be sure to have the car cold, or at least cooled down. we just reached into it. thats all really.
00 5MT AWD 2.5 RS - New Project
Yup, were talkin about the same thing. That part has about 15 seperate names. So were you going in from the back side of the mani or thru the side between the tubes? From the side an adjustable wont fit and a cresent is too wide to fit in the gap around the bolt. From the back, even with my extensions doubled up the angle is way off due to the various bits of framework coming up off of the block. Thanks again for your time and advice.
1992 SS 5MT
- quasi-mod-o
Project, I can't possibly see how you can replace this valve on an EJ22T without either removing the turbo or the intake manifold.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
from experience: you can get to the connector with a long screwdriver, unplug the connector. Leave the canister purge solenoid in its spot, you cannot replace the bolt even with 1000 dollars in tools...... Remove the two vacuum hoses from the solenoid. The existing wire is long enough to relocate the solenoid over between the injectors near the fuel rail. You will need to buy a longer section of vacuum line. one line connects to it up by the coil pack. the other goes back to a valve over where the original was located. There is a tapped location on the block that you can re-fasten the solenoid. I can provide pictures if you need.
Yes, you can remove the bolt holding the solenoid, but you will never be able to get another started, so that is why you need to relocate it.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
Umm.......
I have changed that one twice on my car. Its a turbo. I got it from the back of the manifold. You have to take the turbo to throttle body piping. I use a 16" extention with a swivel on the end. A pain in the ass t get to, but nothing else had to be removed.
Oh, the secret to putting the bolt back in is put it in the socket, and putting a piece of tape around it to hold it in.
Project_Legacy
I kindof arrived at the same conclusion as you did last night and will be trying to do this today as a temporary fix. A pic would be cool if it is not too much trouble.Bheinen74 wrote:from experience: you can get to the connector with a long screwdriver, unplug the connector. Leave the canister purge solenoid in its spot, you cannot replace the bolt even with 1000 dollars in tools...... Remove the two vacuum hoses from the solenoid. The existing wire is long enough to relocate the solenoid over between the injectors near the fuel rail. You will need to buy a longer section of vacuum line. one line connects to it up by the coil pack. the other goes back to a valve over where the original was located. There is a tapped location on the block that you can re-fasten the solenoid. I can provide pictures if you need.
1992 SS 5MT
Good trick with the tape. I had planned on using that for the very same reason. I did not think about a swivel though.....Ill have to pick one up.stipro wrote:Umm.......
1992 SS 5MT
thehookeup
i just had the same problem on my car. just disconnect it with a screw driver. and relocate the new one somewhere else. all you need is a screw driver , steady hands, and some long needle nose pliers
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
I did this on a turbo car, and I removed the intake components, and then removed the turbo elbow. That gave me plenty of room to work on it.
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
The hell you can't. Remove the inlet elbow from the turbo and you have more than enough space to fit any rachet and socket in there.Bheinen74 wrote:Leave the canister purge solenoid in its spot, you cannot replace the bolt even with 1000 dollars in tools......
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
Boy what a PITA! For now, due to a lack of time, I simply disconnected the old one with the screwdriver/needle nose pliers method, added a longer vacume hose to the purge canister line, then connected the new sensor and cliped it into the holder for the plug wires. And there it sits nice and pretty on top of the mani!
1992 SS 5MT
