any TT owners on here?
tom'72
Post by tom'72 »
I'm a new member and have a JDM EJ20TT BG5B engine in a '72 VW Bug but need some help on properly connecting the vacuum lines that operate the sequential turbo system
here's my project:
http://www.cardomain.com/ride/844382
thehookeup
Post by thehookeup »
hey man i am sorry, i cant help you with your vacumm problem. but i do have to say thats going to be bad ass when you finish it. its gonna haul some ass. Doug vincent might be able to help you. he might have pics before he took his TT apart.
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Maybe the technical info this person has collected will help:
http://au.geocities.com/twinturbosubaru/
206er
Post by 206er »
just do like everyone else and ditch the TT setup for a bigger single.
douglas vincent
Post by douglas vincent »
I don't have any info. I just tore it apart. As well as most of the vacumn lines were toasted.
That is a cool project. Hopefully you don't bottom out on those coolant lines.
Why did you choose a BMW radiator?
sammydafish
Post by sammydafish »
that thing is gonna be BAD ASS!
by the way, the round sensors with bolts through are the knock sensors
- Junior
90L Wagon EJ22E on Toyota CT-26 boost -- Crushed!
95L Wagon on T3/T4 boost :)
www.trdsupra.com [b][url=http://trdsupra.com/library/forsale/]Cheap parts![/url][/b][quote="Imprezive"]alright, I give up, I'm going to NASIOC...[/quote]
tom'72
Post by tom'72 »
Sorry for my late reply (been ill). I chose the BMW radiator because a friend had it in his garage and it was the biggest I could fit anyway.
Plan is to go single turbo one day when my budget allows for it and getting around 400HP at the crank.
Haven't drag raced it yet but when the engine was in before it dit 0-60mph in under 4 seconds easy (easy on the start due to the stock gearbox that was ready to explode)
And that was without boost on the primary, on highways I felt the secondary coming on at around 100mph and it went like a rocket from there.
