The ej22t's are oil piggys
I had noticed a little while ago some liquid down around the knock sensor. It looked almost like coolant....which might have been.
Since I had to remove damn near the entire intake system to replace the IAC valve, I started noticing oil spots. The main spot was where it had seaped through the bottom portion of the throttle body gasket, and through the bottom gasket where the 90 deg elbow goes into the turbo.
I'm assuming this oil is coming from the PCV system. I need to work on putting a catch can in, and see if that helps.
Have any of you other guys noticed anything similar? Did you notice a big difference when/if you put in a catch can?
stipro
Post by stipro »
I have not put a catch can in, however on my turbo swap I noticed oil in the exact same spots. Another oily spot is were the oil seaps out of the top, and around the oil pressure sending unit.
scuzzy
Re: The ej22t's are oil piggys
Post by scuzzy »
Legacy777 wrote:I had noticed a little while ago some liquid down around the knock sensor. It looked almost like coolant....which might have been.
I've never seen oil on the top of my block. Not on my new one, not on the old NA one that had 155k on it (and was leaking oil out of the rear main seals like crazy)
#82 M4 TRSCCA Rallycross
206er
Post by 206er »
my motor leaks a LOT of oil which is really bothersome for having about 5k on my new motor.
its coming out of either the rear main, rear of the oil pan gasket, or that wierd plate on the back of the block.
all new seals and I used permatex#2 on that plate, I'm thinking maybe I should have used hylomar? the permatex said it was ok for oil.
:x
thehookeup
Post by thehookeup »
well that plastic plate on the back is called a baffel plate. its a total pain in the ass. its all dependent on how you cleaned the mating surface of that plastic. cause one i cleaned it on a wire wheel. i know im retarded. and it leaked, but i also stay away from the cheep permatex, i like to use " THE RIGHT STUFF" that stuff seals anything in less than a minute.
as far as the oil on the top of the motor i would have to say PCV, but my dumbass buddy, didnt put in the oil retainer bolt on the top of the motor and he started it up , holy crap that thing pumped out so much oil on the top of his motor. and the crazy thing was he couldnt see it cause of the intake mani. he found out once it warmed up enough to start to burn
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
IronMonkeyL255
Post by IronMonkeyL255 »
The spot that's been bothering me the most is right under where the turbo>TB elbow meets the TB. I have tightened the snot out of that hose clamp, but to no avail.
Rio Red '91 Legacy SS
Matt Monson
Post by Matt Monson »
thehookeup wrote:well that plastic plate on the back is called a baffel plate. its a total pain in the ass. its all dependent on how you cleaned the mating surface of that plastic. cause one i cleaned it on a wire wheel. i know im retarded. and it leaked, but i also stay away from the cheep permatex, i like to use " THE RIGHT STUFF" that stuff seals anything in less than a minute.
I never use the plastic baffle plates on my engines. There is a metal version of it available that is well worth the cost. Basically, anytime the backside of the engine is exposed for repairs (clutch replacement, rear main, etc etc.) I would strongly suggest that people replace it with a metal plate...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
my3awds
Post by my3awds »
206er wrote:its coming out of either the rear main, rear of the oil pan gasket, or that wierd plate on the back of the block.
Funny, my engine is doing the same exact thing on all new gaskets. You didn't happen to get a gasket kit from ebay did you? If you did, I'm never recommending this kit to anyone else. The rear seals anyway. Everything else is cherry.
So did you say for sure it's oil, or do you think it might be coolant as you stated earlier? I know my TB coolant lines were cracked so it was leaking around there. If it's oil, you're probably right about the PCV system. My ex had a GSX with a small fuel-filter inline of the PCV to the intake tube and it went black in a week. No real perforance gains. It did clear out the turbo of oily resadew though.
Subaru Impreza Ver6 replica with Ver4 Type R motorset.
Mitsubishi Evolution 4 replica with Evo4 GSR motorset.
I've bypassed my TB coolant lines. So there's a possibility it's coming from that connection. But it's been that way on my old motor for ages and not had a problem.
I'll just have to keep an eye on things.
dzx
Post by dzx »
With my old engine, after a couple months of driving, I could remove the intercooler and drain about half a pint of oil out of it.
///M
'93 Legacy SS - part out
206er
Post by 206er »
intercooler makes a pretty good oil condenser for the PCV eh...
