According to Haynes manual, I should check the fuse if my fuel pump is not working. Its states that is fuse is blown, replace. It blows again to check the relay. Now I have found the relay, pump, sending unit etc. But not fuse.
I would like to know if the fuse exist or if the car only has a relay. It is not anywhere near the main fuse box under the dash. It is also not in the fuse box under the hood.
Pls help.
Oh I looked at at thread from Canadian guy (I think pg 6 or 7) where he asked but no answer was given to location of fuse. Your diag. you linked to him only shows the relay which is the same diag I have on my Haynes manual.
thanks again
J'
Fuel Pump Fuse Location 96Outback
Get up, get out and do something you never done.
The haynes manual is wrong......there is no fuel pump fuse....only the relay.
Many thanks man
Thanks for the quick rspns. Now I can go back and try to stick my big fat hands in the small cavity they decided to place the relay. This is by far the best forum site I have been too also. Very detailed, and informative. Many thanks again.
J'
J'
